Schattenjager
Anyone know the bolt hole size for this?  I tried the bolts that came with the hitch but they are standard, course theads etc. and won't thread past two turns.
			M12 x 1.25 x 60mm
Remember to ask for grade 8 bolts.
Since the 2 lower holes doesn't have a thread I suggest you to add a
(inside the cross member) reinforcing steel plate as wide as possible,
with the 2 holes pattern pre-drilled and if you can, weld the nuts on
it, before inserting the plate. This will help you to install the
bolts with only one wrench. Don't forget to torque the bolts to at
least 80 lbs and you should use one flat and one pressure washer for
each of the 4 bolts.
It's a cheap and easy way to reinforce the cross member and limit
somewhat it's flexing if you pull a trailer with some tongue weight.
	I wouldn't go with fully threaded unless the unthreaded shank is too long in that length bolt. Is it?
Also suggest actually torquing those bolts to spec with Locktite in the threads.
I even performed a dye penetrant NDI inspection on the cross member welds, just to be sure.
What do you do when you're bored Dave?
