Micro Locks
sargeek
As anyone installed one of these to help prevent a vehicle from rolling while using a winch?
Work around your truck with confidence that it won't move.
■For use on trucks with a dual brake line system, the Dual Lock locks fluid in your two brake lines simultaneously and prevents your truck from rolling.
■If a drop in brake pressure is detected, two built-in pressure warning switches sound the horn alerting you to check your brakes and/or re-engage the Dual Lock.
■Includes a basic assortment of brake fittings and instructions.
oonimog
I have a Hurst line lock installed on my FJ40. Althought it was designed for drag racing, it works great for winching.
alexrex20
in my experience, i have trouble with traction and keeping the tires from sliding, not with the brakes not being able to keep the tires locked.
ntsqd
Heretic Car Camper
FWIW It's "Mico Lock", no r in it.
A friend has one in his front brake circuit. Between it and a truly functioning parking brake he can lock up all four tires while out of the truck supervising the winching job. If he slides during the winching, he just 'digs in' a little with 4-Lo in reverse.
sargeek
Yes, I meant winching out another vehicle, not your own. At times the e-brake is not enough to hold the winching vehicle. It is easy when you have a co-pilot to depress the brakes, but sometimes I have been short handed and would like to lock all 4 brakes.
DanoWall
