How to build your own mufflers...
Metal Twister
Highly Motivated
After looking at the inner workings of Flowmaster mufflers and doing some research I thought I would take a crack at building my own. I was after something unique that would minimize the scrape factor at the same time I did want to do my part to insure that they were spark proof. Catching the forest on fire while wheeling... Well lets just say it 's not going to be my rig blowing sparks.
I made a pattern for the housing out of cardboard to insure that my measurements worked correctly. I then made a set of baffles plates with a series of 1" holes in just one side of the baffle plates. Some smaller center separation baffles were made to hold the main baffle plates apart. The same number of holes were placed in the center separator plates but in different patterns. Plenty of Mig spot welds holds it all in position.
Additional sound baffles were then added in between the main baffle plates. Different shapes and angles were used to mis direct the sound waves.
The inner baffle assembly was slid into the shell and tack welded in from the inside where the baffle plates ends were accessible. I then bent some strips into a L shape and capped off the slop between the shell and end baffle plates.
Then end caps were formed with a 2 1/2" dimple die hole in the lower center. I Pressed a piece of tube with a 2 1/4" ID. through the flared hole and welded the back side solid. Welded the end cap on and repeated the process for the rear of the Muffler.
On a side note: Both mufflers with baffles, heat shields, and end caps used up a 4' x 4' piece of 18ga. Cost was $19.00
Metal Twister
Highly Motivated
These will be mounted on an FSJ Jeep fairly close to the floor so heat shields were added.
They sound a tad deeper than the flow master but still very throaty.
Bcghosttowns
Wow,i have never heard of anyone building a muffler before.Very nice work.
If you were to sell one for a truck and you needed to measure just like you have done their what sorta price would you need to make it worth your while?
just curious.
Metal Twister
Highly Motivated
Im not telling...Im not in the muffler business! But like everything else its just time. The more you make at one time the less time it takes to build one... Make sense? If I got it down i could build one in 3 hours, At $50.00 per hour plus materials. Im guessing around $175.00 ea. Thats why the title is how to build your own muffler.:sombrero:
chasespeed
I have one question...
Did you check your exhaust back pressure before and after?
I am curious as to the impact of the flow of the exiting gasses.
Looks great. Simple, and easy to replicate and modify to fit what ever application is needed.
Chase
Metal Twister
Highly Motivated
I checked the back pressure with and with out. I dont have a scientific way of measuring it. I can say that it feels to be about the same reduction in the exhaust as the Flow masters. With one of mine on one exhaust and a flow master on the other it feels the same. Of course I do have a cross over so it might be compensating for the pressure differential. With both flowmasters on then changing to mine they feel very similar. With nothing on there is a Great difference in the pressure. But then again its only going by feel and a general consistence.
DrMoab
Impressive to say the least!
Makes me wonder what the market is for custom mufflers that don't conform to normal sizes.
chasespeed
Well, if I were to put a muffler on my truck, it would absolutely have to be custom. As it is, my pipe is 5" diameter...and I have been trying to find a way to deal with it from the rear axle back...
A custom muffler would have been perfect on my Rodeo...
I toyed with the idea.. but, for the cost of a 20 dollar replacement... I just kept tearing them up...
Chase
ntsqd
Heretic Car Camper
A friend made a muffler a while back for his TJ. He was looking for a more throaty sounding muffler w/o spending the money and he was just curious to build a muffler. It came out great except that it was quieter than stock.
FWIW a simple manometer tapped into the exhaust on each side of the device under test can be made with some clear tube, some food color in water, and tape it to a side window.
wiki
JJackson
I have heard of guys building motorcycle mufflers but must say this is the first time I saw one built for a 4wheeler.
S
Scenic WonderRunner
Guest
That's Awesome what you have done!
I was just told this past week that I need a new CAT and Oxygen Sensor to pass CA. smog.
So I have been crawling under my truck. Then I found that my Magnaflow Muffler with only 30K miles on it has cracked at the factory weld seams on the front and back. My muffler repair dude says he will fix it for $15 bucks when I come in with the new CAT this week. Who would have thought that a Magnaflow would last less than 30K?
Oh! And there is a new law in CA. that every CAT has to be CARB Compliant. Even if you are Pre OBDII.....! Which cost's you more!
Can you see the break around the Factory weld?
(pics to follow. I'm sorry, I can never make the attachments work.)
Blizz
Very nice!
It's empty inside? I mean, did you put some rock wool inside or something?
We made a circular one for my mate (He has a 3.0TD 4Runner as mine) but it makes too much noise for my taste, but only did chambers with a big hole in the middle...
Cheers,
David
Vario 814DA 4x4 Germany
