My Camper/Crawler build:
brennanriddle1
Has anybody else had issues with a Currie HD steering set up? All of my adjustable and non-adjustable ends were trashed in about a year. Which led to my driver side knuckle being bored out, the front track bar bushings and heim joint going bad, and my tires wearing out extra fast.
A need for a new tie rod, drag link, and 3 adjustable ends from Currie is in order, along with a RE bushing and heim rebuild kit for the front track bar and a new HD track bar mount for the rear axle.
Oh and i've done some work on the jeep while it's been sitting around waiting for parts. Here are the pics:
Here is what's hiding in my glove box now(didn't mind giving it up considering everything get's dusty just sitting in the glovebox). This thing is going to be very useful i can tell...
How the whole shabang looks:
Yes, the blender works: :wings:
I used a clear plastic lidded container for a replacement glovebox, it just sits comfortably between my seat and the e-brake:
Ah and of course, one of what i call my "boredom mods", the watering hole:
brennanriddle1
Center of gravity issue?? just FMI(ForMyInfo)... if you keep heavy stuff (cans, etc) above the lighter mattress...
a bit of an issue during the "flexy" times?
jus' my .02C :) :) :)
I couldn't agree more. That is why i built a new jerry can rack. :coffeedrink:
Also picked up this baby. teaser pic. I'll eventually start it's own thread in the trailer section.
It's an m116a2 from Gov liquidation. 400 bones.
brennanriddle1
There have also been a few updates to the JK.
It isn't being used as much for expo as it is for crawling. Although when the trailer is finished, just about anything with a hitch can be considered an expo vehicle.
Ever since this:
A new Bestop trektop has been added. New rock krawler 3.5 long arm suspension. HD flipped drag link and steering box brace. I put on the HD poly tie rod a while ago. Steering stabilizer, 37" red label krawlers, 17" allied beadlocks and limit straps. Phew!
brennanriddle1
And last but not least, This is on it's way for the TJ:
It should keep the bed in the back of the TJ weatherproof and will also give me an extra bit of covered room.
brennanriddle1
So i mounted the jerry can on the passenger side of the rack. What should i put on the drivers side? Another gas/water can? an air compressor? power tank? Something new and creative?
I like the thought of something new and creative.
Ford Prefect
Toilet
Get a toilet seat munted to a bracket that can be removed (like a trailer hitch only smaller) and that would be a great addition to any jeep! You could even mount a little bar out of the tail light to hold the TP! :D
By the way, Does your Two Piece Soft Door set have a lock on them? It looks like a keyed lock in the middle of the handle there....
brennanriddle1
Toilet
ah haha that would be good. a toilet, a shower of some sort?? hmmm... the ideas are flowin.
And yeah it's got a lock on there. Not that it would actually stop somebody who really wanted to get in but hey, it's the thought that counts.
brennanriddle1
Put my new to me rear wheels/ tires on. They actually came off the JK and we're adapted to my TJ thanks to spidertrax.
Also mounted my hi-lift up on the rear rack. Some ext. shots:
SWbySWesty
Fauxverland Extraodinaire
seems like it'll be a lot of weight up high and in the rear...don't want you tipping over backwards if you go up a steep incline!
brennanriddle1
With the exception of the jack (which isn't permanent), i like to keep lightweight items up there.
Typically i throw a few dufflebags full of sleeping bags, air-mattresses, and pillows up there.
When i'm not camping the gas can comes out, along with the bed/kitchen, and the racks are empty. (crawler mode = light weight.)
Will also be adding a suck down winch behind the front grill to act as a counterweight to steep inclines. Hopefully it will offset the slope enough to keep me from going backwards.
Does anyone use an inclinometer?
might help..
also, what sort of effect does a relatively light tongue weight have on that sort of thing? the m116a2 i picked up is pretty well balanced. I can't imagine tongue weight is more than 100-150# fully loaded. (i could be way off.)
darrylkd
