AT Horizon Hub Swap and a few other Mods
Romer
I did not take any pictures. There are clear pictures and simple instructions that Martyn sends with the sink via e-mail in a PDF.
Basically put bolt the bracket on the sink, put the sink where it goes, mark the bracket, drill the holes, bolt the bracket to the trailer and put the sink back on the bracket
Borrego60
Rendezvous Conspiracy
OK so it sounds like a small "L" bracket that gets mounted, reason I ask Is I was thinking about a faucet I do have the water tank and a 1gpm on demand pump and did not want anything to interfere with the mounting of the sink ect. But I thank you for the response.Do you still have the pdf file?
Romer
OK so it sounds like a small "L" bracket that gets mounted, reason I ask Is I was thinking about a faucet I do have the water tank and a 1gpm on demand pump and did not want anything to interfere with the mounting of the sink ect. But I thank you for the response.Do you still have the pdf file? I do have the file if you want to PM me your e-mail addy.
Here is a picture from AT's web site. You can kind of see the bracket
Romer
Not really a trailer modification per say
I bought an LED light from AT that can be attached to the camper or used on the truck as a reverse light.
I struggled with where to mount it as I envisoned being able to use it in multiple places.
Over a beer and Cigar I came up with an idea.
Why not mount it on a stake with a long plug to the aux outlet, then I could move it around
Bought the stake at Harbor Freight.
attachment.php
attachment.php
attachment.php
gp01
