doc holiday
Is it ok to store a propane tank on its side or should it be vertical?
			No its just a 5lb bottle for my stove.
Besides local laws that may prevent it... What are everyones thoughts on storing the tank inside vehicle?
Russell
Thats where I carry mine, usually. Of course, it's not connected to anything and I don't smoke. It's probably safer there than strapped to the outside.
Russell
At the welding supply store I use they have photos of cars that had tanks stored in the trunk. The problem is that if the tank leaks, the enclosed trunk will trap the fumes, and if there is an ignition source the explosion will be catastrophic.
So don't ever store fuel tanks in enclosed areas.
Your passenger compartment is a little less worse from an escaped gas containment perspective (you usually have fresh air coming in and could smell the leak if it happened), but do you want to be breathing those fumes? And if you don't have the tank strapped down well enough it will bounce around in an accident with possibly deadly results.
Which all explains why RVs have those tanks strapped to the outside of the vehicle/trailer while everything else is inside![]()
ehh i dont know, i have emptied the contents of a full 1lb'er into an air matress and lit it off, it wasnt as big as i'd hoped.
