RTT Fitted Sheets
Connie
Day walker, Overland Certified OC0013
I made my own for our TechniTop, but it was more like a sleeve using two flat sheets stitched together that had cut outs where the velcro is (technitop velcros to the base, not sure about how others are secured).
Corey
OverCamping Specialist
What size is the mattress?
On my Maggiolina AirLander medium I used full size flannel sheets with a fitted one on the bottom, and the flat on top that came in the set.
Works perfect for the mattress in my tent.
My mattress is about the same size as the dims for the shell.
57” x 83”
The sheets I used are very high quality, got them here.
Pinzon 160 Gram Yarn-Dyed Flannel Sheet Set
For the down comforter I used a winter weight one from The Company Store.
I like it so well I have one on my bed in my home too.
La Crosse® Ultra Warmth TCS® Down Comforter
CX25 twin, 72x92" 35oz
kai38
In mine I have a fitted King size sheet, It needs to be tucked under at the foot, a king top sheet (no fighting over covers) & two down comforters on top.
shogun
Stop in Sportsmans wharehouse (orange grove/thorneydale). They have some sleeping bags of large dimension that may fit and arent very pricey. I wouldnt consider them for serious cold weather, but probably overkill for around here.
cactusjk
I have not measured but the platform is 48 X 96". Anyone have the 1200 mattress dimensions?
57” x 83”
Signcutter21
CactusJK,
Good questions. If I would have known, I would've measured it this weekend. I'm in the same boat as you. Thinking of using a full sheet and sewing a second one to the bottom. If you find anything out, let me know too.
mike
SilverBullet
If they are anythign like RV mattresses, the next size down works great (an RV King mattress fits a queen fitted sheet perfect...)
Gear
Explorer, Overland Certified OC0020
You might want to contact Paul at Equipt. The new Eezi Awns are coming with sheets included. He might be able to order just the sheets. Worth a call. Here is his website if you need a quick link www.equipt1.com
The new sheets are a nice addition.
zhukoveli
