Tell Me About 1999 LC's --UPDATE On Page 3
Nick B
Local Toyota dealer took in trade a 99 LC with 81,000 miles . They want 14g's for it . It looks real good . So what's the good and bad about this year ?
Forgot to check if it has the rear locker .
CSG
Slee Off-Road has some good info on their site regarding model years and changes.
Pedro
Capitan rally fluffer
The 99's all have rear lockers. The price sounds good.
The front diffs are the weaker versions, but if you aren't going to wheel it in the rocks hard, you should be fine.
We have 200k miles on ours, and we have had very few issues with it.
Cackalak Han
With 81k, the 90k mile service is coming up. It's pretty costly (timing belt/water pump), so be sure to have the dealership do this before purchase.
Nick B
Will the stock front diff hold up to general four wheeling, no rock climbing ? Also is there a way without spending mega bucks to make it stronger ?
mph
Nick
Get an ARB up front and your are golden. Stronger up front and a fully locked vehicle in case you are ready to have a little fun:) '
By the way, I just bought a 99 and love it. Fully locked and ready to go! Make sure you get the 90k service done before you buy it. Expensive!!!
wesel123
Absolutly love mine. 128,000 trouble free miles. Great daliy driver if you don't mind the gas milage. 2nd on the 90k service about $1600 so add that to your negotiation.
Equipt
Supporting Sponsor Presenting Sponsor of Overland
I've had my '99 100 Series for 8 years now. Closing in on 200K miles. I have slightly modified :sombrero: it, and have beat on it severely. Absolutely the best truck I have ever had. If you aren't planning on the rock crawling stuff too much, the front diff won't bother you at all. The upgrades are spendy. An ARB / regear will set you back a few $K. I keep looking for alternatives to the 100, but haven't found any I like.
CSG
On the 90k service, shop around. Our local Toyo dealer is at $800-850 not the $1600 wesel mentions.
spressomon
Care to elaborate? :ylsmoke:
I use this rig harder than probably some if not most 100 owners. Some of the sub assemblies, including the rear axle bearing design, is probably not designed to handle the type of usage I've subjected this rig to over the past 5-years. 4-rear axle rebuilds in the past year due to seal failure. Quite possibly I bent the housing...or not.
But at the end of the day I absolutely hate not having an axle system I can service and maintain myself (on the recent Utah trip alone we did over 130 stream crossings). There is no way to check, as on the 80-Series FF, whether water has contaminated the seal/bearings. And when its had enough it just fails...sort of like Russian Roulette...you just don't know when or where it will happen.
The pressed on bearing retainer and all the other related parts is about a $675 PER SIDE parts and labor (mostly parts!!!) at any Toyota dealer. You'd need a couple expensive SSTs and at least a 40T press to do it at home; no possible R&R in the field.
99.99% of Hundy owners don't see the SF as a problem...
Clemtiger84
