My legs must have grown longer
grahamfitter
For the last two years since I learned to ride a motorcycle, I've been reading this statement from so many smart motorcyclists on the internet it must be true:
My 30" inseam is too short for <insert long list of bikes here>.
For example, I'm definitely too short for a KLR 650.
Here's the paradox: As of this morning I own a 2008 KLR 650 and I can comfortably reach the ground with a flat foot on one side or tiptoes on both sides.
So, obviously, one of those facts must be wrong. Since it can't possibly be all those expert motorcyclists on the internet offering the same sage advice, the only other possibility is my legs must have grown longer.
That's definitely a bit weird but I can live with it, especially if it means I can now reach the cookie jar without standing on a chair! :ylsmoke:
Cheers,
Graham
rionorte
Hi Graham.
That is great to hear. I hope to purchase a used 2007 Kaw KLR 650 - I always thought of it as a Land Cruiser of the Dual Sports. Thinking and thinking about a Hanna rear bumper for years but made more sense for me to stick a dual sport back there.
I'm 5'6'' with a 32-33" inseam (measuring from the inner groin with tape). Haven't seen the pre 2008 models closely and you have been shopping around -So you think I'm tall enough for the earlier model? :roost:
R_Lefebvre
Yeah, I've got a 30" inseam, and I got used to riding a WR250 with a 39" inseam. So, a KLR really can't be that bad. It's something you just get used to. It's really only a problem off-road. You have to plan your stops. Well, not plan but... I've only been caught out a few times.
That being said, it helps if the bike is light weight. I suspect a 39" 250lb bike is much different than a 400lb 35" bike.
Check for lowering links?
I have a 34" inseam and sitting on the KLR in the showroom a couple months ago had me tip-toeing to keep vertical.
frgtwn
Tiptoes, like, in really really long feet?
Or,
two flat tires?
I have an 05, Corbin low seat, and it is kinda tall. (for me)
Dale
grahamfitter
<snip> So you think I'm tall enough for the earlier model?
Lets find out exactly how much taller I grew first. :)
Or,
two flat tires? <snip>
Size eight and normal tire pressure.
Check for lowering links <snip>
Option number three: the bike has shrunk!
I'll check on the lowering links. It also has a Sargent seat which according to the previous owner isn't any lower than stock but I suppose it could be.
This KLR came farkled with side protection, skid plate and luggage racks and the aftermarket Stebel horn sounds like it should weigh several hundred pounds by itself. Maybe the whole bike is sagging because of that?
Is there anything else that could make the bike lower?
Cheers,
Graham
goodtimes
Expedition Poseur
Lowering links are pretty common on KLRs, low seats are all over the place too.
Of course, the more probable answer is that after a couple years of riding, you are becoming comfortable with only getting your toes to the ground, instead of flat-footing it.
Something else to keep in mind, it's not just the seat height, but also the seat width. Great example is the 800GS. The low seat is about 1.5" lower than the standard seat, but it is also wider -- so I'm on my toes (both feet) with either one of the OEM seats.
MarcFJ60
Just goes to show pretty much anybody can ride any bike. It's just a matter of what you're comfortable with.
My XChallenge actually DID shrink - sort of . . . After adding the rear racks, soft panniers and a Pelican on the back, I am solidly on the balls of my feet. The extra weight must have dropped the seat height a solid inch or more.
My wee has the same problem. I even jacked the rear suspension to compensate, to no avail. :(
BigAl
You are in dicey territory, I rarely go against internet experts:)
T.Low
I'll chalk it up to this:
White water boaters are capable of all sorts of things.:bike_rider::roost:
Have you seen the ADV slideshow pic with the BMW Dual Sport with the Liquid Logic strapped on the back with the dog sitting in it? You don't see sea kayakers doing stuff like that.
grahamfitter
Yup! :)
I think its one of Ara's photos. I saw it a few years ago before I learned to ride a motorcycle and was wasting countless hours on the internet pondering what bike I should get and where I should ride it.
The only problem I saw with his setup is if one paddles solo, and I imagine this chap does, the dog can't shuttle the bike. That and in order to strap it sideways across the moto, his playboat had to be so short it would make almost every ferry above a carnivorous hole a hero move! :sombrero:
Cheers,
Graham
oskarf150
