I'm still happy with the cooler.  I had it out for
3 days of camping two weeks ago and it worked well for all my food but the ambient temperature was not too high.
Also we put some lettuce near the top, it ended up touching the cooling element and freezing.  So I guess you need to be careful where things are placed.
I run mine off a 20lb tank with an adapter, after measuring with a scale it uses just over 1lb/day on the maximum flow setting.  I also run my BBQ on propane so I disconnect the cooler to cook and then reconnect the cooler, it does not seem to have any trouble recovering from the momentary interruption.
One recommendation, drill some drainage holes in the bottom near the flame.  It rained some during our trip and the bottom tray filled up with water.  The slightest bump would cause the flame to be extinguished.
An annoyance is checking to see that the flame is still going.  I'm always paranoid that the flame will go out for some reason.  You have to bend down all the way to the ground to see if the flame is still lit.
1. I have a 115V/400-watt deck-mounted power outlet in the bed of my Tacoma with the Off Road package- Would you guys advise plugging in the unit and using that outlet while driving?
Yes plug it in, the thermostat only works when operating on AC power.
gasman you seem to be knowledgeable about CO emissions.  The campground I was at had seen some bears recently so I didn't want the cooler right next to our trailer at night.  I wanted to leave the propane going so I walked the cooler and propane tank into the bush quite a way from our site.  With a normal cooler I would have just put in in the vehicle and left it.  Do you think that I could have left the propane going and put the cooler in my minivan overnight with NOBODY INSIDE?   I would also put it on a non-flammable surface since the flame is so low. It was just such a pain to lug the heavy cooler into the bush.
Rob if I were you I'd pull the trigger on this cooler, there is nothing near this price with similar features.  If you don't like it I'm sure you could sell it used or just keep it in you garage as a beer fridge.
Jason
