2500Adventures
Well in an effort to perhaps make my Jeep Liberty more conducive for the Expedition style travel I'm going to do a straight axle conversion.
Currently the setup is an OME Frankenlift from All J Products out of Big Bear Lake, CA.
The future holds the following for the Liberty:
South American Iron Cast HPDana44 front axle with 4.56 gears
XJ LPDana44 with 4.56 gears
Both axles will have OX cable driven lockers
Both axles will have Chrom-Alloy shafts
Tom Woods custom drive shafts
Currie Anti-rock bar in the front
Clayton Off-road Custom long-arm kit
Fox Dual Coil-Over shocks in front
Eibach coils to go over the shocks
OME863 (80 Series Cruiser) Springs rear
OME N74L shocks rear
Other things to be added as well to compensate for the new axles and such.
I'm also getting my new 10lb Powertank system mounted in the left rear side of the cargo area. I'm cutting out the plastic side paneling to weld in some decent brackets to hold the powertank mount in place.
Kevin's Offroad out of Phoenix is doing the work and later this summer or early winter an ARB front bumper/Warn winch setup will be added as well.
Kevin's Offroad also makes these very nice roof racks for Jeeps that go the whole length of the roof so I'm going to see about getting one of those as well, in hopes that it will suffice in getting a roof top tent stored up there and still have room for other items.
Following that will be new rock rails as the stock ones have already been used enough and given to a new owner. There is another guy in PHX that makes some for the Liberty so I'll be checking with him about a set.
Finally, I will need a new rear bumper. With a swing-out for the larger 35" tire I'll most likely be running, maybe put some provisions on it to hold sand tracks or a jerry can or 2 or both. Somewhere also in there I'll be working on modifying the crew area. I'll finally work on a solid storage system in the rear cargo area for tools/parts/gear and with the smaller rear seat removed work on the hard-mount for the Engel fridge I have. My thoughts on the optimization of the space are changing daily so I'm always changing around the spot for stuff...
Any thoughts on the build are welcome or ideas on optimization of storage in the cargo area.
Just hoping to have a good portion of things done by April of next year and for sure by 2012 for my Alaska/Canada Adventure.
Before:
Before:
