Superu
Hope everyone had a great weekend and someone is in the mood to offer some helpful advice to my most recent issue.
Here's the setup:
03 Chevy Suburban 5.3l V8
Not sure if the alternator is the stock 105 Amp or the 145. Will check VIN and update post.
Starting battery is stock lead acid Group 34.
Second battery is a Group 31 Diehard Platinum in a National Luna PPP.
PPP is located in the rear of the truck and is wired with the NL kit including heavy gauge cable and anderson connectors.
Here's the problem:
After installing a brand new DH Platinum 4 weeks ago and running my Engel MT45 loaded with containers of water and Gatorade I started to notice that the battery level indicator on the PPP would drop overnight from 100 to 75 and sometimes even to 50% charge. This seemed excessive considering the Engel was set to fridge, was maintaining temps in the high 30's and the ambient temps were in the 80 - 95 degree range.
I had read about these DHP's having issues so I called Sears and they said it sounded like a bad cell. Brought it back last week, got a new one from a different Sears location and the issue appears to be recurring this week.
So, before I make a bad assumption about this battery, I thought I'd better post up for some wisdom here. :ylsmoke:
BTW, the NL PPP appears to be working as designed. It lights up, waits the standard 5 minutes before starting the charge cycle and looks as though it's charging as designed. On 7/4/10, I had a 220 mile round trip that I would think would have been enough to top it off. (full disclosure: we did have the AC running, the Engel plugged in and a laptop going the entire time.)
So, if I am running a 105 amp Alt; is it not enough? What about a 145?
Would it make any difference if I replaced my starting battery with the Optima Yellow Top that used to be in the PPP? I took that out because it was exhibiting similar issues but I assumed it was due to it's small size and lower capacity and I wanted a bigger battery for upcoming multi week trips.
Is there something else I am overlooking? When I plugged in a little LCD voltage meter to the front cig outlet, it showed 13.6 - 13.8 while underway.
Thanks!
Here's the setup:
Here's the problem:
Thanks!
