Allpro Light Hoop Modification
barlowrs
Well, as much as I like my Allpro front bumper, perhaps the only complaint I have about it is the front light hoop. I did not like how it far forward it is angled, more like a stinger than a hoop. And I also do not like how the light mounts hang lights very high and very far forward:
….so, I decided fix it.
First thing was to cut the original base plates off. I could have made new ones, but it was easy enough to just cut them, then use a mill to machine the left over “welds” off. One I got the plates cut off, I re-cut the angle at the bottom of the tube so it would mount in a more vertical position, as apposed to sticking out forward.
I had already bought a set of Lightforce 170, and the original hangers hung them too high up and off the bumper, whereas if I mounted them directly to the bumper, they sat too low:
so I decided to add my own light bar to mount them where I wanted.
I took a piece of 1.25” (Chromoly was the only scrap I had around, so now my light bar is the strongest pipe on my truck) and bent it out so that the lights would clear my front grille. Then figured out a good height by mocking the lights up.
After that I threw on some Light tabs for the lights:
Gave her a quick shot of rustoleum:
And voila, here is the new light hoop that no longer sticks out to far:
And the lights sit centered, right where I want them:
(Write-up on the lights to come shortly..I have to finish the wiring diagram)
freeze
What happens if you wanted to upgrade to some 240's?
There's also a spacer you can make or purchase if you want them directly on your bumper.
I've always had mine drilled into the bumper. All-Pro didn't used to make the light bar holes. But I also found it looks kinda odd hanging off the top and the spacing was too close together.
barlowrs
I thought about 240s but honestly, with the exception of yours, they always looked to big to me....I really do not understand what you did to make them look better, but for some reason, on your rig (mayeb its just the rest of the truck) they look MUCH better than other ppl with 240. Even my gf noticed it. I asked her opinion and showed her yours and another tacoma with 240 on it. She said the lights were too big on the other one but the lights you had were just right (I didn't tell her they were the same lights and same setup..haha)
freeze
They are big! I think they're larger than my face which is really odd comparison.
Hmmm. I'm not too sure, perhaps it's the spacing and the height of the lights?!?
off_to
