I've got H20 flowing into the passenger compartment lol
this thing never keeps me bored
i've got water, started out hot now cold - when the AC is on
is it just the tray spilling?
its going to ruin the floor if it keeps it up
solutions?
lol
lake_bueller
There are some tubes for the AC unit that run from behind the dash and down under the truck. It's most likely that the tube is plugged. First crawl under the truck and pull the end (be careful, it's probably full of water). I ended up "snaking" the lines to remove excess gunk.
R_Lefebvre
Just remove the carpets, Linex the floor, and install a bilge pump. That is the ultimate solution to leaky Land Rovers.
overlander
X2. your drain line is blocked. Every car with A/C has a drain line.
chrisvonc
Crawl under the vehicle and look up on either side of the transfer case/bellhousing area. You will see two rubber nipples drains for the A/C unit. These get clogged with dirt/gunk, or seal shut. Massage each one to open it again. Once you clear these the water inside shoudl cease.
Rovertrader
Supporting Sponsor
at least from the a/c lines :victory:
thanks fellas!
*dons rough weather gear*
I knew it was going to be a high maintenance relationship but I never suspected I'd be massaging my Rover :ylsmoke:
revor
Massaging your nipples?
overlander
once open, let them dry out, and then shoot some lubricant up into them (like lithium or something) to prevent them from surface adhering again.
This conversation is degrading quickly...and I'm not helping.
Wander
So...to repeat
1 Massage the nipples on your D2
2 Lubricate them
3-I'm kind of afraid the ask:coffeedrink:
darrylkd
