Overland Vehicle Design & Development Videos
Martyn
Somthing wrong with your JS. Make sure the references are all correct and that the JS files are in the right spot. IE: AC_ActiveX.js and AC_RunActiveContent.js are there and the path is correct.
But to get it working again until you can figure it out, remove the <noscript></noscript> tags around the videos.
<script type="text/javascript">
AC_AX_RunContent( 'width','522','height','317','src','http://www.youtube.com/v/ZP5lc4sXWs4?fs=1&hl=en_US','type','application/x-shockwave-flash','allowscriptaccess','always','allowfullscreen','true','movie','http://www.youtube.com/v/ZP5lc4sXWs4?fs=1&hl=en_US' ); //end AC code
</script><noscript><object width="522" height="317"><param name="movie" value="http://www.youtube.com/v/ZP5lc4sXWs4?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZP5lc4sXWs4?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="522" height="317"></embed></object></noscript>
Thanks for the help, and welcome to the Portal.
The script and no script code wasn't in the original embedding code. I think it got there from Dreamweavers compatibility checker.
When I removed just the no script it did very strange things to the page.
I ended up pasting the original embedding code back into the web page.
Does it work with Explorer now?
Martyn
Compressors, air systems, On Board Air
A couple of weeks ago I spent the day with George from Extreme Outback. We were doing the on board air installation on my truck. I managed to video all of the preparation work and got George to talk about Compressors and air systems.
George is an authority on all aspects of air systems, and his company Extreme Outback caters to the overlanders, the military, and mining and construction companies.
I just finished editing the 11 part series on Compressor, air systems and On Board Air, you can see on our Tire Repair & Compressors page.
SuperCal
Perfect timing, i was just discussing air systems with a friend of mine and was about to start researching... You just made my life alot easier :)
Thanks!!!
Martyn
Thanks!!!
If I can be of help let me know.
csjk
Martyn,
What are those Thule "1/2 saddle bags" mounted to the interior walls of your Commanche? I can't seem to find any info on them.
Gren_T
Hi martyn i am just rebuilding an aircon compressor to use on my LR90 OBA. a timely thread great vids..
also noticed your avatar.. a fellow Cymry.?
regards all.
Gren
Martyn
regards all.
Gren
Gren
We are almost brothers! I grew up in Swansea and then made my way over to the USA via New Zealand and South Africa. It's a little more complex than that, but that is the condensed version.
Glad you enjoyed the videos, let me know how your project progresses and if I can be of help.
