Central NV Airway Beacon & Aircraft Crash Search
PHXtaco
After working on the New Mexico Airway Beacon Survey http://expeditionportal.com/forum/showthread.php?t=46648, I decided to start looking for beacons closer to home whenever I go out looking for aircraft crash sites. Fortunately the San Francisco to Salt Lake airway runs right through central NV where I am currently looking for a number of old crashes.
As usual I am off to a late start. (Rather than leaving Friday night, I did not depart until late morning Saturday.) Driving through Reno I realize that I am not going to make the desired search area until right before sunset. Not wanting to totally give up the day to just driving without doing at least some exploring, I recall that the mountain staring straight at me on east side of Reno/Sparks had an airway beacon on it according to the old WWII Aeronautical chart I had studied the week before. A quick glance at the NG Topo map on the computer (set at level 4) showed a road going to the top of the mountain from the next exit. So I dove off the freeway exit and fortuitously found an open gate at the road (it actually looked like the gate never gets closed) and headed up the dirt road. After bouncing around in 4 wheel drive for the last 10 to 15 minutes I am faced with this sight… hmmm, the road ends before the top!
I stopped to look at computer, zoom in to level 5 on the Topo, sure enough this road ends on this plateau here and there is another road on the other side of the mountain that goes to the top! Teach me not to look more closely at the map when I deviate from advance planning! Not wanting to have to back track all the way around and then drive up the other road I decide to hike the short (vertical!) distance to the top. Looking back at the truck part way up the hill.
As I crest the ridge I am greeted by this sight… a VOR, the modern day airway navigation system. Doh! Only makes sense to place the modern navigation system on the existing route, especially the high point just outside of town. If I had just looked at a modern aeronautical chart… (What was I saying about advance planning?…)
Because this unit was humming quite loudly, and because I know that it puts out a navigable signal for 130 nautical miles, I decided I didn't want to get too close to the transmitting antennas. I shot this picture in case the pole to the left is a beacon, definitely not the 1930s beacon, but perhaps a more recent one?
Looking back at Reno.
Zoomed in at Reno-Tahoe International Airport.
Headed back down the hill. It almost looks as if this dirt road is an onramp for I-80!
Headed for the next hilltop I suspected had an old beacon along the airway route, my direct access is blocked by a locked gate and mining land! Looking on the map (level 5 this time) there is a pipeline road that runs along the other side of the mountain. Unfortunately I have to drive quite a ways on the freeway past where I am at before I find access to the pipeline road. But at least the drive back is fun!
The road to the top of the hill where the beacon was located had obviously not been used for some time—probably not since the beacon was torn down—and was probably nothing more to begin with than a quick dozer blade to move large rocks out of the way.
As I approach the top I see a familiar sight: the 4 base legs sticking out of the ground! 2 for 2 and at least this site had something left—it was a good way to salvage the day!
PHXtaco
A style of tower structure I had not seen at a beacon before, probably something newer than the original 1930s beacon tower.
It is very narrow—possibly just the top???
Conduit and broken lens glass.
A light bulb.
The base legs of the tower.
Electrical cable.
Just like the cable we saw from El Morro CAA Air Field in the back of the rancher’s pickup.
Interesting electrical junction box.
Measurement of a beacon leg.
PHXtaco
Looking down the “road” from the beacon.
Looking down the “road” from the beacon. The mine that blocked direct access is straight ahead.
Returning to the pipe line road.
Hwy 50!
Sand Mountain to the left.
Rain! I was not expecting this (but at least I was prepared for it). I was planning to camp on the other side of those mountains.
Fortunately by the time I got to the other side the rain had moved on.
PHXtaco
Setting up the grill as the sun went down.
Sunset.
Watching the sunset from a hot spring.
Camp the next morning.
A couple poser shots!
Now off to meet a friend for a hike to look for an aircraft crash site.
Antelope (I think).
After my time in Arizona, I am always fascinated by water in the desert.
PHXtaco
This spring was flowing well enough to feed two small ponds.
A stampede of horses off in the distance.
Cross traffic!
I usually focus on crashes that occurred in the 1960s or earlier, but for some reason this 1996 crash caught my attention. A USN Top Gun Aggressor pilot was killed when he ejected too low while engaged in air combat training. This picture was taken partway up the mountain, looking back down into the valley we came from.
Evidence of a fire from several years back—although at first we wondered if it had been from the airplane crash, the fire was much too recent to be from 14 years ago.
Terry scouting down below.
Finally found the crash site. The impact crater is in the center.
A small piece of the plane.
An X made from rocks is in the crater.
Close-up of the X with some aircraft parts next to it.
PHXtaco
Not much was left of the plane, as expected. Modern crashes are usually fairly well cleaned up.
Looking down the hill I noticed a pole with something hanging from it.
It ended up being the tattered remains of a US flag and a touching memorial that his “comrades” (they were simulating being Russian pilots) put up for him. The plane’s canopy is just to the left of the memorial.
Close up of the granite marker and a plastic model of an F-5, the plane he was flying.
The F-5’s canopy. After a moment of silence for LCDR Ryan, we headed back down the mountain.
Terry headed on his way, and I decided to use the rest of the afternoon to explore some of the Nevada backcountry. I spotted some towers on the butte in the valley (turned out to be modern microwave towers) and there were some natural springs on the other side of the dry lake I wanted to see. With those targets in mind, this road looked promising. (I love how most gates in NV and AZ have “Please Close Gate” signs on them – in CA the signs usually say “Keep Out”)
I stopped by an old windmill, but did not take any pictures, but as I drove around it I heard a funny sound…
I had ended up driving over a short piece of old fencing and it wrapped around a front CV shaft!
The piece of fencing is above the tools I used to remove it. Took over 45 minutes in the heat. And after this trip I added a heavy duty wire cutter to the truck’s tool kit.
Entering the edge of the dry lake.
PHXtaco
Looking out the passenger window.
According to the map, there was an old homestead at the natural spring. Large old tress in NV are often an indication of a homestead/ranch.
Quite a bit of water at this spring, but there is a local on the other side right in front of the left tree who is giving me the evil eye...
…uh-oh, he's coming over…
… I am out of here!!!
Driving along the far side of the dry lake I notice a black dot on it that just does not look right.
I locate a 2-track that leads out that way.
Hmm, what could it be?
Is it…
…yes it is. It's an old car.
Brian McVickers
Administrator
Staff member
Great post.
It's great to see the bigger picture of what people use thier vehicles for!
Sounds like you have an interesting hobby.
:coffee:
PHXtaco
I think he got stuck a while ago!
Can any of you car people tell me what it is?
Back on the road. Looks like there's an intersection ahead.
Yes, but what is the other way???
I elect to take the long way back through Dixie Valley, though in hindsight that was a bad choice due to fuel.
A fixer upper expedition truck—even comes with a high volume water tank in front of it (needs to be installed).
What was interesting that while the blading looked fresh, there were patches of weeds growing. The blading is probably older than I thought and this road must not get too much traffic.
Back on a main road, and getting mildly concerned about fuel. I have the computer calculate the distance to Fallon, 52 miles. Not good, the scan pro says 18 miles left in the gas tank. I recall seeing a gas station at Middlegate. It is one of those places you drive by and you're not even sure it's open—and if it is, you're not sure if you even want to go in there. To top it off, it is Sunday and already after 7:00 PM. I think about driving as far as I can towards Fallon and then calling AAA, but elect to make a run for the gas station at Middlegate; if it's too late and they are closed, I will just camp nearby.
But still take time to check out a set of hot springs on the side of the road.
It turns out the Middlegate gas station is open (open till 10:00 PM every day!) and it's a friendly, hopping, local place. They also have a bar, restaurant, and rooms. They guy on the porch (no banjo) was even friendly, though he thought I was a geologist based on my truck. He lost interest in our conversation when he learned I was just an archaeologist. Looks like I will be able to drive home tonight to the SF Bay area after all! That was close on gas… but not as close as I will get the following weekend (To Be Continued…)
PHXtaco
Great post.
:coffee:
Yep, definitely a tool of the trade, though I am finding when I choose what to look for I seek out projects that will require backcountry travel and then usually choose longer more interesting routes to get there! :sombrero:
shortbus4x4
If you go by the place where the F-5 crashed take a good outdoor new flag to put up and take the old remnants down. I'll chip in some for the cost of a new flag. Looks like you had some nice scenery on your trip. Look forward to your posts from your next adventure.
HMR
Rendezvous Conspiracy
Love it!
Your airway beacon searches have made for the best "Expo" threads I've ever seen on this site:
1) You have a very interesting purpose for the trips.
2) Your truck is an integral tool for the job.
3) You do a GREAT job of telling the story with pictures (nice photography, btw).
Keep up the good work!
PS- I'm guessing that was Mustang VOR you hiked to?
soonenough
Couldn't agree more; this was a really cool, fun, and unique report to read. And there were some really cool pics in here. Thanks for taking the time to put this report together :sombrero:
1leglance
I am completely hooked on these reports...like others said the use of a 4wd for such a cool task, the great pics and best of all the story that goes with them.
I admit to often passing by towers/beacons and having no idea about the history, but now it will be more fun to think back on these reports.
thanks!
PHXtaco
Thanks for the comments everyone!
Yea, if I go back I plan on replacing the flag. It is a bit of a hike to get in there, so it will likely be a while, but I do have one friend who wants to go to this site, so he might help push the timetable up.
The following weekend I actually found more interesting beacons. Should get that trip report up next week, but right now I am getting ready to head out for this weekend!!! Central NV again, but this time volunteer work with a non-profit aviation historical group I am involve with.
zhukoveli
