Mercedes-Benz G-wagen Spring Spacer
Fernweh
Supporting Sponsor
FOR IMMEDIATE RELEASE
July 11, 2010
Products: Polyurethane Spring Spacer for Mercedes-Benz Geländewagen
Company: G-wagenacessories.com
Contact: Karl E. Volger, karl@g-wagenaccessories.com +1-818-887-4092
G-wagenaccessories.com introduces the all new G-wagen Polyurethane Coil Spring Spacer. The new Spring Spacers have been designed by Karl Volger of G-wagenaccessories.com for the use in the Mercedes Geländewagen. The new spring spacers are molded from a polyurethane elastomeric material by world renown and market leading company exclusively for G-wagenaccessories.com.
This is a very solid addition to an overland Mercedes G-wagen for a safe method of a modest body lift
CONSTRUCTION
• Cast in a multi faced mold from a proprietary polyurethane elastomeric material
• Spring Spacer net thickness is 30 mm
• Precision casting for the Mercedes G-Class coil springs and spring mounting plates.
USES
• Provides a modest body lift of 30 mm
• One size spacer for the front and a larger sized one for the rear axle to fit the different coil spring dia.
BENEFITS
• Modest 30 mm body lift
• Allows the use of larger wheels/tires
• Reducing the Noise, Vibration and Harmonics (NVH) levels
• Fits all G-wagen models. This is a vehicle specific part and does not fit other makes
• No other modifications necessary to brake lines, ABS cables, shock absorbers
• No other hardware necessary
For High Resolution Photos and or more information please email request to Karl at: karl@g-wagenaccessories.com
P.OBox5731 :: Santa Monica, CA90409-5731USA :: tel. 818-887-4092
https://www.g-wagenaccessories.com
Fernweh
Supporting Sponsor
when are the 50mm available?
The 50mm Spacers.....wish they would be produced by a Robot.....
I'm still haggling over the outrages engineering cost (for the additional 20mm) plus buying the minimum production run......
How many sets do you need?
http://www.g-wagenaccessories.com/index_files/Page339.htm
zimm
mmmmmmm..... how about 50% off a second pair so i can glue and stack em?
:peepwall:
Fernweh
Supporting Sponsor
:peepwall:
Not sure I can endorse that procedure, however the spring spacers stack up pretty nicely.
Ok, I'll accept your (one-time) request for this :smiley_drive: test.
"All men by nature desire knowledge." (Aristotle)
All liabilities arising from this experiment will be yours with no exceptions.
Please contact me at karl@g-wagenaccessories.com for payment and shipping details.
V45W_Proto2.5
