Bring on the Tech
mongosd2
So Rob said bring on the Tech...so here are the current project's:
2001 D2 with Toyota FZJ80 axles, custom suspension with front coilovers and converting the rear to the same. 1.6 hi-gear tcase...
1983 D110 imported from Boliva...4.0 Engine/ZF auto-lt230 tcase swap. TD5 Dash and Ashcroft center console. New electrical harness, with interface to autobox and dash. Fuel system replacement plus a lot of other ****
1996 D1, stock but finishing a head gasket replacement...
Importing a 1983 D110 Hicap Pick up with a 200Tdi/LT77...
bring on the questions...
AxeAngel
1st question. Where did you mount your hilift?
2nd question. Hi pinion diff up front? Let me know when you do the rear. I have a toy v6 w/ elocker sitting in the garage waiting to go in. Trying to get a gb on axles. Got 4 members on here interested so far.
Nice trucks!
-Sam
mongosd2
Nice trucks!
-Sam
I found that the floor of the garage is the best place, but bolted to the rollcage in the D2 is it's second home...
Not a toy swap from kieth, but a complete axle swap...HP front with a ARB on a air switch and a detroit in the rear...
1leglance
how tough is the auto swap into a Defender?
As a left below the knee amputee I can drive a stick but would be better off with an auto...however I worry about the swap being more hassle than it is worth
R_Lefebvre
I'm guessing it's about as hard as swapping an R380 for the ZF. Which is to say, not hard at all. All the parts are off the shelf.
R_Lefebvre
Well, you've got the cooler lines to run. Of course, I also did that since I went with a manual trans cooler. But yeah, you're taking away a pedal, not adding it, and no clutch lines, and the shifter linkage is no big deal.
Kickdown cable on a ZF22?
Viggen
Just here...
Ill be doing a complete refresh of my rear axle in the next week or so. New pads, rotors, bearings, seals, Ashcroft HD axles and drive flanges. Im going to see if I can keep the camera handy and document it.
Then, the real fun starts when I go ahead and rewire the accessories on the truck. Drew up the diagram a couple of days ago. To be safe, Ill be taking a 3 day weekend to get this one done:
Maybe there should be a no BS zone DIY thread. No comments, just tech.
Antichrist
Just do better than I did.
My wife had the camera and photo documented every step of converting my '95 Disco to D90 brakes, along with a nearly all new brake system.
MC, SS flex lines, calipers, rotors, bearings, seals, pads.
Then I promptly formatted the CF card. :Wow1:
mongosd2
The swap is easy, the electrical system isn't so much hard, just time consuming...
gp01
