Any 12V power packs like this in the US?
Lance4me
I saw there's 2 breaker in the photo, could you please explain what's the purpose of having 2?
spikemd
Tremors- thanks again for the write-up. Very comprehensive and well thought out. Thanks also for the links to the individual parts and the wiring diagram.
This is the kind of system that will work best for me for a couple of reasons.
One, it is portable and you can take the battery out of the truck and put it next to the fridge rather than always going back to the truck for a brew.
Two, I have two rigs and can easily transport the battery pack between them. Makes more sense for me. I will hopefully start working on this next month.
I may look at a Minnkota box since it has the battery charge status, 12v accessory plugs and terminals already installed. Also, I may consider a one-way diode isolator and not include the switch in the dash. I like your set-up but probably don't need the capability of jumping the truck from the switch. If I kill the main battery, then I will be forced to take the backup battery/box to the front of the vehicle for a jump. I still take jumpercables with me everywhere, more to help others than myself. I also won't be keeping the battery-box in the vehicle at all times. Great set-up for a reasonable price.
The portable PowerStation has worked well for me for short trips since it is so easy and cheap. Not a long term solution, but I didn't have the time/money to put in a system last year before our 2 week trip to the Southwest (Death Valley, Vegas, Grand Canyon, Albuquerque and Moab). Surprisingly, that little 18ah battery lasts a long time (one full day in moderate heat) but I assume it will not continue to last that long as it is not a deep cycle battery.
Lance4me
Wrangler North West
Many of the electrical components can be purchased from them.
Or as follows-
The Box is made by MTM its the sportsmans SPUD2 dry box. It can be found here http://www.northwestshootersupply.com/mtmsportsmanplusdryboxspud-1-11forestgreen-2-1.aspx
The 200 amp solenoid
Manual Reset Circuit Breaker
Disconnects
Power Point
I cant remember exactly where I got the voltmeter. I'm sure you can find one by googling it.
The switch and LEDS are seperate pieces and were purchased locally at Radio Shack.
Hope this all helps.
Gene
Link for the solenoid is only 85 amp, is it ok to use or should I go with a 200 amp? Thanks for any help.
tremors834
200 amp.
I think 85 amp would be too small.
Perhaps they changed the link or I just flat out screwed up the link. :D
Lance4me
Will this do the job?
[ame="http://www.amazon.com/Cole-Hersee-24143-Continuous-Solenoid/dp/B000XBKHZY/ref=sr_1_fkmr2_3?ie=UTF8&qid=1292386425&sr=8-3-fkmr2"]Amazon.com: Cole Hersee 24143 Continuous Duty Solenoid: Automotive[/ame]
tremors834
I'm actually about to swap out the solenoid relay.
I've gone through 2 of the following stinger 200 amp solenoids on my setup.
images
On the 1st I snapped off one of the threaded lugs with a rachet after cleaning some oxidation that had formed.
On the 2nd one it just stopped working.
I'm thinking of going with a Trombetta 404-1231-032 contactor/relay
zhukoveli
