Better fuel economy for FJ62?
Hltoppr
El Gringo Spectacular!
Best thing I did for my old FJ80, (same drivetrain), was remove the roofrack, keep the tires to 31s and slow down. In Mexico I could get 15-16 mpg loaded; as the top speeds were kept to about 55 mph and under.
esh
A 1HZ swap seemed to improve mileage on mine. :sombrero:
You can get injectors reconditioned and do all the tune up stuff but results for most are mixed. I had a freak of a 3FE and would get 17-19mpg at the altitude it lived its life. At lower altitudes it would get 15-17. It had been regularly maintained at a shop before I got it. Average of what I've read from various sources is around 15mpg.
I completely agree with no roof rack, smaller tires and driving conservatively. There is noticeably less road noise at 55 vs 65 and therefore less fatigue as well.
IMO these are not efficient DD type vehicles. That's why there are Civics, Corollas, and Golf TDIs.
Worldcyclotour
Thanks for the reply.
The reason I ask is that I just sold my Sportsmobile which got 9-15MPG depending on load and whether or not my roof was jam packed. I do frequent trips that are 400-600 miles to destination from San Diego and the fuel cost was always a factor. The other factor is being many miles from fuel stations once I get to my destination and tank range is a consideration. If I could get 15 MPG with a FJ62 then that's better than the SMB. I have a Prius for my DD so the FJ is for the off road trips. I've located two FJ62 for sale and since I have not had one before I'm a bit nervous going with something that I have not had any experience with. I've had Jeep Wranglers which are good but the LC has so much more room inside.
Esh, What's 1HZ swap?
The LC I'm leaning toward the one which has 175k on the clock and looks to be quite original but the tranny seems a bit sluggish at startup. Common?
TangoBlue
American Adventurist
What's 1HZ swap?
I was going to be a wise guy and suggest a 4BT...
Diesel engine swap. The 1HZ is a Toyota diesel engine and parts are not readily available. The former is a Cummins and commonly found in the US... you hear them daily in bread or delivery trucks. But both engines are simple, durable, and have amazing lifespans.
Diesels will often give the FJ60/62 20-25 mpg and massive amounts of torque.
esh
1HZ parts are commonly available, as the engine was sold in NA and dealers can easily get parts off numbers.
I won't start a holy war on the merits of one engine over the other, just want to correct some misinformation.
Christian P.
Staff member
When I had mine loaded with the roof top tent and everything, I was lucky to get 12.
15 mpg may be achievable but that's the upper limit in favorable conditions.
If you are looking for fuel economy, I would look for another option.
njtaco
You can help both power and economy by swapping in a 5 speed manual transmission. It is a well documented modification to the FJ62s.
I get about 12 (around town) to 15 (highway) MPG in my 1988 at sea level on regular (89 octane) gas. Slower speeds (55-65 mph) help of course. I have the stock automatic, stock gears, and 31 inch tires. She is not ordinarily heavily loaded.
Cackalak Han
Would a 4Runner or Tacoma fit your needs better since fuel cost is an issue? I averaged 21-23MPG with my 4Runner/Tacomas on the freeway.
There is no denying the appeal of the 60/62, though.
Christian P.
Staff member
Funny you mention this...that is the route I took. I love my 4Runner. City is not so great but on the freeway I get easily over 20 too.
My FJ60 could not possibly carry any more gear (roof rack and 33x10.5 AT tires) and I am getting 19mpg with a 12HT diesel swap. Cost of the swap is rather high, but my engine was about to go anyway... and the difference between my 2f and the 12HT is night and day.
As mentioned before the H55 manual transmission swap will get you an extra mile per gallon or three. Several H42 transmission swappers have suggested similar results with the addition of 33" tires.
I'll be collecting my parts soon enough for the H42 swap.
Willman
Ditto on the H55 swap!
My 60 is getting between 17-19 mpg...(desmogged, stock tires, no rack)
I love it.
It's a lot of fun to drive
MonteroNerd
