1989 Trooper 5-speed 4cyl
SVS
Not a Cleaner unit available. I have owned this for 5 years and the prior owner was an Isuzu engineer. Just had it painted in July. Had the Dash resurfaced at the same time and a New windshield. New Mirrors.
Leather Recaro "Speed" seats, Momo shift knob, Leather wheelskin. Tinted Windows. New Carpet. New driver door window regulator.
No Rust. Mechanically and cosmetically perfect.
Re-tubed one piece drive shaft, new Trans Mount. Heavy duty steering damper. Used new OE parts for the "big brake" conversion. All four rotors cross drilled. 16" Rims from 2nd gen Trooper obtained from Japan. New clutch installed one year ago. Deaver rear springs with new bushings. KYB Shocks. New fuel pump, starter, clutch master cylinder, check valve and slave cylinder. In Feb of this year New T-Stat, coolant and all drive belts. Radiator in perfect condition. New Cat installed Feb of this year and a Magnaflow muffler.
Computer re-programmed by Jet Performance. Street/Smog legal. Cap, Rotor, Wires, Plugs installed 13,000 miles ago. Throttle body replaced in 09.
Custom Welded on 2" receiver from Hitch Crafters. . New head Ported and 7 angle cut on valve seats with all new valve train, cam, timing gear, water pump, timing belt, etc. Done by prior owner an Isuzu engineer/ASE Master Tech.
I don't really want to sell this but it's time. Looking for an enthusiast buyer that knows what this is and will treat her well.
$5000. Southern California.
Wander
That is one clean Trooper! Bump for a nice rig.
Just curious...are the seats purple or is my monitor off?
SVS
They are PURPLE...Used in a SEMA show car a few years back.
A Mitsubishi Eclipse. They looked so good I left them as is...
Purple is the "seat" of royalty you know...Fitting for a KING!
SVS
Any links to more pics?
What's the set up in the rear seat area and cargo?
JDB
I have new carpeting original side panels and a Sub Box in the rear along with the Original Rear seat. The Sub -Box is optional if a perspective buyer has interest.
Never kitted out (for camping/travel) the rear area as others have.
TX_TAHOE150
I had the same identical truck...color and everything except the seats. This truck was one of the best trucks I've owned. Bone stock, It went through stuff that surprised seasoned off-roaders (with modded trucks) that were doubtful that I could follow them wherever they went. What a pristine truck you have there my friend, brings back great memories. The aftermarket support is winding up on the troopers as well, even back in the early 90's I was able to find a lot of strong drivetrain goodies and expidetion accessories. bump!
xander69
