Just Ordered A Winch..
Box Rocket
quoting because your truck looks great. and also, do you have a pic of the mounts?
I was planning on building my own, but at only $200 thats not bad!
You can see the mounts in the first picture of my post. That is the optional gusset kit that you can get from Trail-Gear. Well worth it IMO. Comes with the scab plates and gussets. They are designed to be welded to the frame, but I suppose with a little custom work and some creativity you could make them bolt on.
Rab89
I am thinking of a pic of the mounts with them on the truck..
Box Rocket
Don't think I took a pic of that, but I'll try to get one. They are just welded to the frame. Those angle brackets are welded along the bottom and side of the frame and I plug welded the holes in those plates too. Pretty simple.
lkretvix
