Inexpensive Lighting Options.
beast1210
Exactly what I did and have been using for 2 years (here's my write-up) - they definately throw some light down the road
the 4509 only has a 25hr life, there is a number of company's doing LED. But that goes out of "inexpensive". Look for PAR36 lights. 500 lumens
http://www.stolztelecom.com/p36slc-par-36-12-24-vdc-replacement.html
http://www.aircraftspruce.com/catalog/elpages/whelenpar362.php
http://www.aircraftspruce.com/catalog/elpages/whelenpar363.php
http://www.whelen.com/_AUTOMOTIVE/details_prod.php?head_id=12&cat_id=74&prod_id=469#
video from Whelen
http://www.whelen.com/_AVIATION/media/parmetheus/parmetheus.html
GTABurnout
I finally got a light bar so I am looking for a cheap bright set up. So far I think I will be running some Ebay KC style lights with HID conversions.
Life_in_4Lo
To me there's no excuse to ever wire a light without a relay. I cringe when I see people run full power through an in-cab toggle switch.
BTW, standard Bosch type relays only cost a buck or two (if you have to buy them), so I don't see that it would raise the price much at all
If your switch is rated for the amps, why do you need a relay?
relays add up, add wiring, connections, take up a lot of space in tight areas...
I run relays but I also have some 20a switches and just run clean for some of my low draw items.
As long as the draw is less than the wire gauge and switch rating, I don't see a problem?
corax
You'll find out if that switch ever malfunctions or your wires ever get abraded through to the conductor.:Wow1::ylsmoke:
Seriously, I've been taught to do it from a safety POV.
Safety and installation flexibility. As a bonus, if the in-cab switch or relay fails I can still power the device with a simple jumper wire at the relay connector. Plus the extra run of thicker gauge wire required to run straight off the switch and the voltage drop (loss) you get through that type of set-up. I prefer one low amp fuse for all the switches with a thin gauge wire bundle between the cab and the underhood relays (less intrusive) and a short run from the battery-relay-device.
off-roader
In addition to the safety factor, this is another good point. With a relay, you can run the thin low wattage (18G) wire into the cab instead of large high wattage (14G) wire. Will definitely make a bear of an install a much easier one.
oskarf150
