Depends on the locker. A full replacement carrier like an ARB or detriot locker should be no problem. With a 'lunchbox' style locker.....like a lock-rite, you may run into issues trying to install one in a limited slip carrier.
I had a local shop install a (Power Wagon-TracRite?) locker in my 9.25 AAM front differential, 2006 ram megacab. It took a little grinding (including a notch for the wires) and an Eaton switch kit. But it works as advertised. Haven't messed with the LSD read except to replace the 3:73 gears with 4:11s.
I don't believe ARB offers anything for the 9.25, but yes on the D44. If I remember correctly, it's a Detroit that's available for the rear. That's one of the reasons I had a new LSD installed rather than a locker when I geared "up" from 3.53 to 4.10. I was worried about "streetability". But I could be wrong...I frequently am! :sombrero:
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
