jesusgatos
Been thinking a lot more about trailers lately. Think I'm going to follow your lead here (rear slide-out). Just makes too much sense. Only have to figure out all the details...
This is the "semi-custom" configuration I am now offering (I figure each truck builder is going to want different lengths, treads, etc.).
Not the "sexiest" photos, but they have gotten years of testing.
I
Putting the steps parallel to the truck makes a hand rail easier to rig - or do without. If you run them straight out with out a hand rail you have a worrisome fall risk.
r
I use the accordian steps going directly out from the door in the back. I installed a swing out hand rail typically seen on fifth wheel RV's because I too was worried about the fall risk. I initially thought the hand rail would not stick out far enough to be effective but I was pleasantly surprised that it's functional for the complete walk up and down the steps. I don't have a picture.
My handrail probably would not be as useful with a full height door but since mine is a pop up that requires bending over to get thru the short door, your hand is low enough when exiting that it is in a position to be held firm while walking down all the steps. If a person were standing fully upright when exiting the door, the handrail would be too low to be useful for the first couple of steps.
Love that you're making the whole box detachable. Are you going to build-in some kind of camper jacks or...
Finally just spent the time to read through this whole thread. Can't believe how far you have gotten already! That's great. Really impressed with how it is coming together.
Let us know if we can be of any more help...
As for your A/C, you might want to consider putting something down between the frame rails, to save your clearance height up top. We used a Sun Power Technologies that is a high efficiency DC-based (i.e. not AC via an inverter) so that it will run off your solar/batteries. Great units, but only 4,000BTU.
Anyhow, great job so far!
Jay.
Ah, I see where you're going with that. Clever. I've been thinking about how to build camper jacks for my truck, but it's a bit more complicated when the bottom of the box is over 4ft off the ground....and they're all electric because I needed them to work in a bi-directional fashion (the camper jacks also act as part of the retaining system for the box).
