What type of compressor do you use?
  • Bargain Portable Compressor (think MV50, Pep Boys, etc.)
    Votes: 47 49.0%
  • High Quality Portable Compressor (like the ARB or ExpeditionAire)
    Votes: 16 16.7%
  • Smaller Hard-mounted Compressor (like an ARB)
    Votes: 14 14.6%
  • High-output hard-mounted Compressor (like an ExtremeAire)
    Votes: 19 19.8%
  • Engine Driven Compressor
    Votes: 8 8.3%
  • Total voters
    96
1leglance
I have run Extreme Outback High Output and Magnum on my vehicles and each had a 2 gal tank.
I love the fact that I can air up tires, run air tools, dust off the interior and do a bunch of other stuff with a setup that is always there and ready to roll.
corax
HF knockoff of the Viair here. I modded it by adding a regulator and safety valve, as well as standard M type quick connect fittings. Spent about $120 to buy and mod it.
I keep mine portable so I can share or move around as needed. I am keeping an eye out for one of the mini-york compressors that came on some VWs - looks just like the full size York (which I have, but never installed due to its size), but is a bit smaller. I think the mini York comes in 6 or 9 cu.in versus the full size York's 10 cu.in.
mini york on the left - one thread and another thread for a bit more info
One of the "good" HF compressors (no plastic cover on the cylinder) stays in the back of my 4runner. After buying it 4 yrs ago, I immediately took it apart to port the cylinder head, bypass the on/off switch and change the power cord to 12ga (less voltage drop and a happier motor).
if anyone's interested, here's an excellent write-up on a hybrid HF / MF1050
alexrex20
I had the ARB CKMA12 and hated it. I had to warranty it THREE times. I finally got smart and sold the last warranty replacement. Now I'm using a hard-mounted Viair 450C-IG with a 2.5gal tank. Airs up my 33s and powers my lockers more than well enough.
cruiseroutfit
What was failing on it? I've not warrantied three since they came out and I've sold/installed dozens and dozens? Were you using it just to air up or for locker operation too?
Brian1
I use a Viair 480 200psi compressor hard mounted under the hood with a 2.5 gal. tank in the rear between the frame rails.
jim65wagon
100% duty cycle Viair 330C (the C because it's shiny chrome) and a 2.5 gallon tank, front(behind the grill) and rear(behind the license plate) quick connects.
alexrex20
the conrod bolt was backing out of the crankshaft. i figure it was my mounting location - under the hood. even though that's one of the most popular locations to mount them, it did not agree with my Pathfinder.
oh well. consider my vehicle a fluke. because as you say, this type of failure is almost unheard of, especially 3 times to the same person. :coffee:
VIAIR 450P-A Portable Air Compressor. I bought it based on the Overland Journal review, which was dead on accurate. I couldn't be happier.
gp01
