Dash Rattles - How to Cure?
SirCampalot
I have a dash panel that rattles and it is quite annoying to say the least. Does anyone know where I can purchase that felt lined tape that dealers and car manufacturers use to eliminate such rattles? I think a small piece of this tape at the clips would take care of this nuisance.
Thanks in advance!
spressomon
Thanks in advance!
Another material I use for the same purpose: 2-4mm neoprene. We have a bulk fabric store here that always has it at a reasonable price. Zip tie it around wires/wire bundles, components, etc.
Willman
A little hit of the Beastie Boys with the Brass Monkey.....then if that doesn't cure it.....Bring the Thunderstruck with AC/DC....
Problem solved!
:elkgrin:
SirCampalot
Check with a local upholstery shop. They'll have some.
Great idea... thanks. I may check with some audio shops too.
Get a better stereo....rattles go away
No can do... got the good 'ol integrated NAV in my POS :)
Great idea... gracias!
imma give you all the most perfect excelent redneck solution to everything on a rig, duck tape and jb weld, if the duck tape dont fix it the jb will, and it not, as my shop teacher says, "if you cant duck it, ******k it"
flipstick
