oil changes and dip sticks
Applejack
when you change you oil to you go by what the dipstick says or by the amount of oil that you know you are supposed to put in. I know I should put in 5.4 quarts but my dipstick always shows it about a qt low.
corax
I always go by the dipstick. Are you taking in account the amount of oil that it takes to fill the oil filter?
tanglefoot
ExPoseur
I usually fill 'till the dipstick shows the top of the "OK" range. Then after starting it and letting it fill the filter, it ends up in the middle of the range.
1911
Dipstick. You will never drain out all the old oil due to surface tension.
CA-RJ
Expo Approved™
I always start with 5.5 quarts. Usually I check the dipstick but sometimes I forget to when I'm finished. I do check the oil frequently doing the oil change interval, so if for some reason I am a little low I catch it before it becomes a problem.
4xdog
Reported capacities are a starting guideline. For me, the dipstick is a direct measurement and therefore preferred.
Of course, if there's a big deviation I double back and check everything to resolve what's up.
Lynn
Like my buddy who put 8 quarts 'in' and it still wasn't showing on the dip stick? (forgot to put the plug back in)
V45W_Proto2.5
