97 Disco hard start
eflatlander
I have a 97 discovery that is very hard starting when cold. It does not seem to be getting any fuel. If I dump some in the intake vacuum port I can get it started and it runs fine. Fuel pump? injectors? fuel pressure regulator? Any input would be helpful.
Thanks!
Eric
Wander
Only when cold?
My 94 had hard starting issues-turned out to be leaking injectors but I ended up replacing the fuel pump and filter as well.
eflatlander
Hard start
Yes, although it's hard to say for sure it's about 1 below here right now and I don't keep it in the garage. last week we had a blizzard here (Iowa) and I had it at work inside and it started right up.
Eric
ColoDisco
I would check the cold start injector. Pull it when cold and stick it in some container and try to start your rig. should spray a bunch of fuel into the intake.
sven
Cold start injector? This isnt CIS fuel injection form a 82 VW Rabbit.
Check if the fuel pressure holds when shutting off the engine. Use a fuel pressure gauge and if the pressure drops off immediately, you either have a leaking injector or a bad fuel pump.
ColoDisco
Hence the reason I stated I am not sure! :)
Luckily I have not had any fueling issues on my rig.
ipgregory
Could also be a bad pressure regulator or fuel line leak as well with the same syptoms.
flipstick
