corax
My old 4runner was never very well insulated even from new - it's a bit drafty, the interior cools off quickly and takes awhile to get everything warmed up in cold weather (heater works fine).
I've been reading recently about using Thinsulate as a sound absorbing material in the hopes of using it for the interior side panels - Toyota already uses it on the Prius, and it's also common in marine applications. My thoughts being that it's lighter than Dynamat or other products, is somewhat moisture resistant and serves a dual function without having to be glued or adhered onto the panels (a plus if you ever have to get behind it to run wires, etc). The only downside is that for any sound deadening it seems you should have at least 1" thickness. So sandwiching it between the interior panel and the metal structure is probably out, and I can't think of any slick way to secure it on the outboard side of the metal structure so it doesn't just fall down into a pile.
In the process of looking at Thinsulate, I ran into InsulBrite. This is much thinner (less than 1/16") so it will fit between tight fitting panels better, though I don't think it'll deaden sound as much.
Before I buy more material and get started on the rear panels, what are my options for making the inside a bit cozier in cold weather?
Here's what I did with the doors so far, with the space-blanket part facing the interior of the vehicle:
http://www.warmcompany.com/ibpage.html said:Insul~Bright consists of hollow, polyester fibers needlepunched through a nonwoven substrate and through a reflective metalized poly film. The needled material is breathable and won’t break down with washing. The hollow fibers resist conduction while the reflective metalized poly film resists radiant energy. The energy, hot or cold, is reflected back to its source.
