Ball Joints
MuleShoer
Time to replace the JKU's Ball Joints. Any recomendations for Ball Joint Manufactures? Dyntracs are out due to high cost
Thanks
Ridge638
Make sure they need replaced, every time I go to my shop they tell me that ball joint failure on the JK's is very often misdiagnosed. I wanted to replace mine with some other work I was getting done but they said that there is typically a little more play in JK's upper joints and replacing them is a waste of money.
wjeeper
Every year I take my Jeep to get safety inspected they say the lower ball joints need to be replaced.......never have had a tire wear funny in eight years and several sets of tires.
I can say with balljoints you dont want to cheap out. If you run duracrap units from autozone don't be surprised when they die prematurely. (went through 3 sets in less than 2 years) In the ballljoints defense I was running large un-balanced bias ply swampers) I switched over to MOOG units and they have been held up great!
I do like the looks of those poly performance units, and they aren't too outrageously priced. I also really really like that both joints are greaseable. Often times one joint does not have a zerk! I understand that many OEM components on vehicles now days are going to "maintenance free" or "lifetime lubricated" parts............however I still prefer greasable units.
MuleShoer
My JKU has 55,000 miles on the original ball joints. And since I am replacing the front axles I wanted to replace the B-Joints at the same time.
Anyway I have seen the poly's on-line but have yet to find anyone who is using them....
Moog is my stand-by choice unles another manufacture gets better recomendations
Bennyhana
I also have 50,000 on my stock JKU's stock ball joints. Every time I check them they are still tight. I just upgraded from the stock BFG's to some 285 70 17 Toyo mt's so we'll see what happens.
The Poly's just came out last month so there's probably not a lot of reviews just yet. Definetly a plus being servicable and all, now just have to get somebody to make servicable JK rubicon 44 front U-joints....that don't cost an arm and a leg..
Brigitta
I just had my stock ball joints replaced with the Poly Performance HD Synergy Ball Joints. Very happy with them!
V45W_Proto2.5
