self extracting from mud without a winch
Mamontof
They had done that before ;)
As many others too
Even attach to 2 wheel drive car make unbelievable performance in mud
Mukiwa
A friend of mine was stuck in a mud hole in the middle of the bush with just himself a rope and a chansaw. He tied a rope 20ft up the tree with a few feet of slack then put his jeep in neutral and cut the tree down away from the jeep. I personaly would prefer using my winch but anything that works works for me!!
Tumbleweed
Many military manuals from the 40-50's show this concept for getting unstuck. Many military vehicles of that era had holes in heavy metal end caps on the axles for that reason.
Northern_Touch
Theres also the reel method where you wrap a strap around a drive wheel and tie the other end to a tree,rock,large immovable object. Some of the VW iltis even had a little hub on the wheels for just that purpose. Anyways with a little luck you giver a little gas and the strap locks tight around the wheel turning the wheel into a reel of sorts pulling you out of the hole.
zhukoveli
