I have an over braided synthetic rope on my winch & I want to replace the thimble & hook with a safety thimble. The origional thimble was put on with a regular back splice & I want to tidy it up with a knot like this on the Master Pull lines :
I believe its a triple overhand knot tied back over itself rather than along the standing part. Keep in mind knots degrade the strength of all manners or rope, especially synthetic ropes.
Once you get past the ad, its the last knot in this vid.
If it is already spliced then why not pull the splice apart and re-splice it? Lets see some pics of how it is done, there are just a few over-braided ropes out there that are used for winching. If you peel do want to knot it, it is very simple but requires you to be able to pull the knot tight, we use a tool that allows us to clamp the rope and pull on the knot using a table mounted winch.
I got the rope back in the UK a few years ago. It's not really done any work at all but the spliced part is quite UV faded now. Just want to get rid of that bit & tidy it up. I have a hand winch in my shop that I could snug the knot up with, I also have an extension for it that I can practice on first
Not really... kelowna is as far as we generally go, even then it's a 6/7hr round trip. If I can't get it as I want it, I'll send you the safety thimble & you can put it onto a new rope for me.
Albert from Canadian 4wd Magazine took some pics of the knots being made last summer when he did a shop tour of Master-Pull. Look for the article in issue 12.
Or a Triple Fisherman's Loop... I get a little lost in the termionlogy. A fisherman's knot is like a two turn overhand. and I think the three turn overhand a "scaffold" hitch... Two turns is a fishermans, three tuns is a scaffold.
The problem with both of these is they are slip knots so the eye wants to pull tight?
Thanks for all the pic's, a great help.... the real trick is getting it snugged up nice & tight but I have a plan for that using a hand puller & prusik knot
The knot's formed round the line (by the tail) before it enters the thimble, when in use the knot want's to slide (if at all) towards the thimble but it all depends how snug you get it to the thimble in the first place. Getting the knot nice & tight is the fun bit as Alex noted, the overbraided rope is quite stiff & takes some pulling to tighten down.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
