Isuzu Rodeo platform narrative
cronk
I purchased a used 2002 Rodeo in early 2004 as my primary driver. I chose Isuzu because it was my cheapest available option for what I was looking for. (An inexpensive 4x4 SUV or 4 door pickup.) That and an Isuzu pickup I had as a kid had left a lasting impression on me. I drove the Rodeo as my daily driver for about three years before I acquired a company truck. After that, I drove it less and less. Eventually, it sat in the driveway more than it was driven. I never had any issues with the truck and could always count on it when I needed it.
With my travel came the opportunity to explore many areas of the United States in my free time. Problem was, my rental cars only took me so far. I had to hike on from there. That was the limiting factor in what I could see and do. So, like all of us on here, the desire to go farther was the basis for my build up. It has been a progressive build from something that I already had on hand. Lots of idle time in my evenings allowed me time to read, plan, dream, and shop.
Looking back, I guess I have always been interested in the expedition type vehicles. From an early age, I remember reading my grandmother's National Geographic magazines. The ones that stand out featured the rain forest expeditions. I remember being infatuated with the articles and, more particularly, the trucks in the articles. Orange colored Fords with campers if I my memory serves me correctly. I guess you could say that the expedition seed was planted around that time.
Over time, I found some Isuzu forums that helped guide me with modifications. I eventually made my way out on my first trail ride, then to others. I still remember my first run. I was a bit nervous and excited at the same time. The feeling of conquering a terrain that I never thought I could do in my vehicle was amazing! I was hooked after that, and extremely impressed with what my nearly stock truck could do! Of course, I wanted to make it better! It wasn't long before I started modifying my truck and trying new things. A few mistakes were made along the way. I learned from those and with each outing came new desires and ideas. I've made several runs at this point and many new friends along the way, some of who lead me to this site. Now, I'm at a new milestone and a new forum. I'm looking over this site daily for information and inspiration. I recognize more and more of my fellow Isuzu enthusiasts, Birds of a feather I guess!
Part of what I like about Isuzu is that it is different. I have never been one to follow the crowd and have always enjoyed building things and solving problems. So I guess I fit right in with the Isuzu community. Modifying my misfit vehicle not only fit my personal style, it proved to be a challenge. Unlike many brands, Isuzu doesn't have large aftermarket support. There are only a handful of vendors. Anything outside of the available parts network has to be fabricated. Part of this may be due in part to the fact Isuzu drivers are frugal to start with. Just like me, they chose their truck based on it's bang for the buck. So I guess that is where my build began, bang for the buck.
If you were to compare a used Isuzu to any other vehicle in it's class, you'd notice that for the cost, it's pretty hard to beat. You can find a nice 4x4 Isuzu for under five thousand dollars, maybe as little as half that if you sort through the bad ones. For that price, you get a full framed vehicle with plenty of life left in it. One that, even stock can take you where you want with confidence. One that comes standard with a Dana 44, strong Isuzu corporate front axle, 4 wheel disc brakes and a strong and reliable double overhead cam V6. Shoot, it even has hemispherical combustion chambers! Granted, it can be argued that there are some weaknesses, every brand has an Achilles heel. For mine, it's the 4L30 automatic transmission. Not a bad transmission by any means, but vulnerable for sure. If you were to buy a Rodeo for your platform, get a a manual or the 2004 Rodeo with the Asian automatic transmission. I can testify that with care, these trucks can and will last, I have driven mine to over 100 thousand miles without any major problems to date.
Some may argue that the IFS is a weakness, but it has served me well through the years. It also allows a lower center of gravity for the vehicle. They have proven to work well even with tires as big as 35 inch. It really depends on your driving style from what I've seen and read. If you spin high RPMs, the cv joints are going to break. The good thing is, they are easy to change out.
A recent concern with these trucks has been frame rot. If you have driven in the salt belt or are looking at a truck that has been driven in salt, check the frame! There is a recall notice due to the rot. I recently had mine checked and it checked out fine. I feel I have circumvented the problem by washing the frame every spring and painting any rust on the frame that has cropped up.
The only major maintenance I have ever needed to perform (besides basic maintenance) has been replacing a timing belt tensioner, an o-ring by my thermostat and just recently, the actuator plug on my transmission. (I changed my water pump when I did the timing belt because of where it was located.) The tensioner will knock like a rod knocking when it goes bad. Both repairs are problems associated with higher mileage, neither job was all that difficult to perform, given proper guidance. There are many good write ups about these available on the web. With proper care, these trucks will last a long time.
Performance wise, the truck does well. It accelerates well, tows up to 5 thousand pounds and stops well with the disc brakes. I have gotten anywhere from 15-21 MPG on the stock truck, usually around 17 MPG. My best mileage was with wind was behind me and driving 60-65 mpg. To date, I have driven it all over the Midwest, South and North-East. I've been on many long road trips and it sits and rides nicely on long road trips. After I added larger tires and the roof rack, my mileage dropped a few miles per gallon. I now average about 15 mpg.
The first modification I performed was to turn up the torsion bars and add taller rear springs. I got my springs from Valley Spring Works but Old man Emu springs were an option too. I went the cheaper route. The springs gave me about 2-3 inches of additional clearance. Around the same time, I added 31-10.5-15 Toyo AT tires which replaced the stock 245-70-16 tires. I ran them on 15” Isuzu rims commonly referred to as snowflakes. To prevent rubbing, I pounded the inner fender lips down with a hammer. Other lifted Rodeo drivers have trimmed their lower front fenders. While apart, I added Rancho 9000 in place of the factory shocks. I played it safe and kept them the same length as the factory shocks. (Use caution adding longer shocks in the front. Otherwise you can pull the seals out of the steering rack.) The Yakima Load Warrior was added around the same time.
This is how it sat after the initial lift.
These were the wheels and tires.
This is a comparison to a stock Rodeo.
cronk
Over time, and with a load of heavy landscape stone, the Valley Spring Works springs fatigued. I resorted to installing 2" lift pucks to bring the rear back up.
Always seeking deals on e-bay, I found the factory brush guard and installed it. I drove it this way for a long while.
This is my first visit to The Badlands in Attica Indiana. This was in early 2006. That’s my nephew in the seat there. He’s a lot bigger now!
As I 1st started traveling outside the Midwest for work, I chose to take my truck rather than renting a car. This particular excursion is one I took when I had a weekend off in upstate New York. While there, I explored the Adirondacks.
I visited the Stillwater Reservoir while there, hiking in about 1/2 mile to the lake for an overnight stay. I was one of 3 people on 72000 acres and the other two had kayaked to the island. I was basically completely alone for the first time in my life and it was an exhilarating experience! Coyotes spooked the Loons near my campsite about 2am. They in turn keep squawking off and on until dawn. Needless to say, it wasn’t exactly a restful night.......
I eventually acquired some factory Rims from a wrecked Isuzu Vehicross that I ran when gas prices spiked. I switched back and forth from the different sets of wheels periodically.
It sat for a while as I traveled further away from home for work. Problem was, I had more free time to search for parts. As a result, I began stockpiling parts and eventually got to the point where I got to put them on.
One trip home, I managed to spend some time with my father in law. This is the kayak my Father N law made me.
I went down to Louisianan for a short project. I had to have a a little fun in the mud while I was there.....
While there, I took the time on a long weekend to hard mount a power inverter.
I used it too! It sure helped with writing my daily report.
I also added an auxiliary fuse panel to a space over my ECM.
cronk
I spent about 3 years in California and didn't get to do much to my truck. I did however, continued to add to the stockpile. All I used it for in that period was home improvement related items but its primary function was dog hauler. While in California, I did manage to do a lot of sight seeing. I visited the Lucerne Valley, Mammoth lakes, Tahoe, The Redwoods as well as some not so natural wonders. This further instilled my desire to explore and camp from my vehicle!
During one trip home, my father N Law and I camped along the Wabash River between Christmas and New Year. We stayed in his chicken coop converted to cabin. It got to about 9 below that night…. Fortunately for us, the potbelly stove kept us toasty throughout the night.
Here is my truck along the river the next morning. Notice the ice on the river!
Eventually, I did get closer to home and was able to begin adding the parts from my stockpile.
The most transforming part has been a TJM bumper that I got on a warehouse closeout.
Before I installed it, I painted it white to match the truck.
I installed factory tail light brush guards as well, they were painted white too.
White door handles off of a Honda Passport added to the white out look.
I had damaged the factory one with too many sheets of drywall.... Basically, I cracked and bent the factory mount. My solution, to use some handicap grab bar ends that I purchased off of E-bay for this very purpose. A few sections of fence post worked perfectly as the rails. I painted it all white too.
To make it a look little different, I added Vauxhall emblems to make a clone of the Rodeo's European cousin, the Vauxhall Frontera. Only exception being the Frontera emblems were withheld since Nissan had the Frontier truck. I didn't want people wondering why I had put Fronteir emblems on my truck.
I had found some Darlington Offroad rock sliders on Craigslist and had them welded on.
Then upgraded to some leather seats from and Isuzu Axiom, they were a direct bolt in.
I plan to apply black leather in place of the cloth on my door panels soon.
Lastly, I took some tires off of another project that I was working on and installed them on this truck. They were 255-75-17 BFG Mud terrains on supercharged Nissan Frontier rims.
Here is a shot of the rack loaded up with wood and camping gear. This was a trip I took to the Uwharrie National Forest with a group from PlanetIsuzoo.
A few trail shots.
I had a bit of an accident……….
Fortunately, nobody was hurt and a team of great guys winched me out with no additional damage. Search YouTube for Rodeo Rollover and you'll see the recovery. Somehow, while on the night run, I missed seeing the edge of a mud boggers ravine and dropped right off the shear edge at an angle. The truck did a slow roll right onto its roof. Had I turned to the right and hit the gas, I would have just wedged myself between the walls of the pit and been stuck really well…….
I had literally just paid the truck off!
The damage was to the rear quarter and roof panel. Thankfully, insurance covered the repair since it was a forest service road. Funny thing is, we had debated switching to liability insurance. I'm glad we didn't! Telling the wife was the most painful part.
The body shop did a fantastic job fixing the truck. A plastic surgeon fixed my right butt cheek after the wife finished chewing on it.
Since the truck was paid off, it freed up some money to start buying the good stuff! I saved up some money and bought some blemished 265-75-16 ******** Cepek Mountain Cats for my 16” VX wheels.
To give the shiny polished wheels a less shiny and more custom look, I used the Duplicolor Metalcast spray to color the polished rims a darker gray prior to mounting the tires.
cronk
This last winter, I went down to Florida to help a member with a project. While there, we went on a short trail ride. I got hung up on the log crossing the ditch, had I had a locker, I would have probably made it, or gotten stuck worse.
Fortunately, I had an ARB in the Q for installation. I purchased one used and already set up and ready to install. It came equipped with 4:56 gears and my ratio was 4:10. I got a rear ring and pinion to match. At the time of the install, I went ahead and added other parts I had set aside. Darlington Offroad dif drop brackets, new CV joints, a Smittybilt 10lb winch, additional auxiliary lighting for the roof and a used Cadillac air compressor, new front rotors and brakes. I also went ahead and freshened everything up and repacked the bearings. Duplicolor caliper paint added a bit of flair. I painted the dif drop and CV joints white just to keep up with the white out theme. New generic shocks replaced the Ranchos primarily because I twisted the tops of the Ranchos off removing them. The Ranchos rode a bit rough anyway.
I had a mechanic install 4:56 gears in the rear, I kept the limited slip for now but have hopes of installing an ARB in at some point.
Spring of 2011 was another Planetisuzoo trail ride at Uhwharrie, the anniversary of my rollover. That being the case, I had to go back!
Prior to doing so, I remounted my roof rack, lowering the rack an inch with new mounts that I made out of some scrap parts. I achieved this by drilling the posts I used for the cross bars to slide my old Yakima cross bars into. Once both sides are bolted down, the cross bars won’t go anywhere. The scrap parts were notched to clamp around the Yakima bars and clamp to the Load Warrior. I also reworked my light bar to look more OEM . I did this by splitting the factory cross bar and mounting it around the stiff aluminum bar that I had used to mount the lights on. To hide the light wiring harness, I ran a scrap piece of window mullion as a backbone along my roof line. I bent it to wrap along the contour of the roof line. It was painted white to blend with the truck.
Using the same scrap materials I did to remount the rack, I high lift jack mounts for the rack. I simply ran a long bolt through the device and tightened it together around the rack with a nut, the remaining piece of the bolt stuck out allowing me to mount my high lift to it. I drilled out and repurposed some old electrical isolators to separate metal from metal.
To mount my roof top spare, I used some old school spare tire mounting inspired by some old cars I’d seen at a car shows in the past, leather! A couple old leather belts worked nicely!
Luckily no repeats of last year!
Here are some of the trail shots from the run.
I smashed my muffler on the run. Fortunately, it was already about shot. I had larger pipe installed along with a Dynomax turbo muffler and vintage Trans AM style tip behind the rear tire. It makes good sound above 2000 RPM but isn't too loud on the highway.
I have a lot more planned for this truck and hope to make my way back West with it sooner than later. I’ll update the thread as I make those changes.
S
Squatchout
Guest
Great thread and write up! Just don't do that Cronkover thing with that beautiful handmade boat on the roof! ha Ha
Cronking at URE!
cronk
Hey Squatch, thanks for the picture and for leading me to this site! It was great finally meeting you. Your Trooper really impressed me.
I appreciate the complements JeepJohn. I see that you are in Florida, I'm not very far away from there, do you have of any weekend getaway points you can recommend? I wouldn't mind getting out to do some camping before it gets too hot.
Martinjmpr
Wiffleball Batter
Nicely done! :elkgrin:
Even though I love my Toyota I always like to see people do something different. I also like the idea of "doing more with less." For the cost of a thrashed out 3rd gen 4runner, you can get a pretty nice Rodeo.
The Axiom seats look great! No surprise they are a bolt-in: It's been explained to me that the Axiom is just a "re-skinned" Rodeo anyway.
I briefly considered a Rodeo back in the early 90's, one thing that bothered me was the 4wd engagement. IIRC they had a button for 2wd/4wd and then a lever for high-n-low. Is that your arrangement? Have you had any problems with the T-case not wanting to shift in extremely cold weather? Just curious more than anything else.
cronk
Nice write up
Hello Van, good to see you here too. Yet another nice 1st gen.
Thanks for the complements! Yes, mine is push button with the lever but I've never had any issues with it. I know more moving parts are a worry and some guys have converted over to the old school setups. It's easy to do too since so many Isuzu parts interchange through the years but I will be keeping mine, I like being able to engage 4wd and go without getting out of the vehicle.
If you know somebody who has converted over, here's a neat idea I got from a guy, I plan to do it on a future build. Basically, you Lincoln Lock a front dif and use the push button 4wd mechanism to make it a selectable locker.
S
Squatchout
Guest
That's a cool Idea if you are careful with the timing. Never thought of that one.
As far as the bush button + lever. I had the same on my 2000 Trooper which I owned for 4 years. I had no problems with it at all. It was kinda handy here in sleet central. Lot's of winters with just a few pacthes on the back roads. Hit the button prior drive through the mess. Push button after and proceed in 2wd. I wasn't crazy about what I call the weak link in the front axle but I rarely hear of problems that aren't related to an old dryed out vacumm line. I prefer that to full time TOD type of system. On the Zoo's you can still use manual hubs on the push button system and completely disengage the front axle from turning when not needed. They just replace the drive flanges. Then you can carry a drive flange in the tool box in case of a broken hub. If you think you might need 4x4 just lock the hubs before leaving the house and use as normal.
bansil
Whats up:victory:
I've been lurking here for a while,finally joined since I have my Trooper now...our other Isuzus don't fit
bugnout
Very Nice write up. Good looking Rodeo :costumed-smiley-007
It would be nice to have a special kind of thread sturcture for this kind of thing. A place that only the OP can add content as you build out your vehicle and keep all the thread comments at the end of the thread. Kind of like a blog format.
Clemtiger84
