Disco 1 SD with only one sunroof?
Smksignals
Has anyone seen a D1 SD with only one sunroof? It is the front one, no rear one. I found this quite odd, but I am no expert. Thanks.
Wander
Never seen one myself but I could see that a dealer might have one installed after it got here.
Dendy Jarrett
Expedition Portal Admin
Staff member
Wander- Indeed the truck you are jones'n for has only one "dealer installed" sunroof.
The good, probably works and doesn't leak! (no drain tubes used on the dealer installed).
The bad - not factory- but you'd be hard pressed to tell.
D
11b4v
while its open, look at it from the outside, top. see if there is a serial number sticker/manufacturer label. if its in German, its a great unit.
Wander
D
I was wondering about that, I don't mind the not factory aspect, especially since it is better than those from the factory!
sven
I owned a 99 SD D1 with the single sunroof. I had the window sticker from new and it was a factory installed option. The sunroof was much bigger in size than the normal D1 roof and it had a real sunshade. It also didnt leak and closed automatically when the igntion was shut off. Very cool!
franko
Yeah I almost wish I could loss my 2 sunroofs in my 95 D1. You can always put a sunroof in BUT can you take one or both of them away hmmm.
abctrash
