Petersons Ultimate Adventure Tundra
01tundra
Oh, and what about your '08? building it up or STOCK? cant imagine
Well....ok.....I did go ahead and add a 2" leveling kit, differential drop, and some BFG A/T's......but that's it.....no....really :D.
01tundra
Yeah, actually it went something like "OK honey, this is only going to be a work truck, I'm not going to do a single thing to it since it has a 100k bumper-to-bumper warranty, and besides.......it's way too big to take off-road anyways" :sombrero:
bkg
Uh....huh.:Mechanic:
01tundra
If you ever get the pleasure to do the overnight trail ride from Sequatchie to Tracy City, TN…….be sure to watch out for the big hole on the right about 6 miles in :eek:!
01tundra
Nope, it's in the body shop as we speak.
I was really hoping enough trees would fall to total it, then I could've bought it back and started cramming that 5.7L and 6-speed into the '01 :D.
01tundra
In case anyone with a Tundra or Taco decides to run a Mishimoto radiator:
Not if, but "when" you get tired of coolant trying to leak from every possible place and hoses about to explode due to the 19 psi radiator cap they provide.......you'll want to find a 13 psi (0.9 Bar) radiator cap to return the system to the factory operating pressure.
Yes, a higher pressure is supposed to provide a more efficient cooling system, but no, it doesn't make a single degree of difference over a 13 psi operating system for our trucks.
So do yourselves a favor and run down to your local auto parts store with a $10 bill and pick up one of the following for a 1986 Toyota Pickup w/ 22R engine:
CST #7513 (pictured below)
Stant #10227
Napa #703-1443
Carquest #33028
And if you really want to build a dependable cooling system, throw away those junky *** worm drive hose clamps and order four T-bolt clamps from Summit Racing. The 1-3/4" clamps are too small (I know because I ordered them to try instead of the 2" I originally bought).
http://www.summitracing.com/parts/SME-240200/
jim65wagon
Sweet.....
Summit Racing; that's like "Mecca" to us car guys; ah the days when I lived close enough to go to Ohio and just look at all the goodies I couldn't afford in that revered building!
01tundra
I decided to add a new air pressure gauge in the cab so I could monitor the OBA system. I went ahead and took pictures of the entire system so I would have all the info in one place.
New Autometer gauge -
ARB mini compressor and air distribution header -
Viair 1-gal receiver tank -
Powertank and OBA system emergency backup bulkhead connector / regulator -
AZXPLOR
