Tentrax tire pressure
EBT531
I recently purchased a used Tentrax with 32" tires on 16" rim. I'm wondering what tire pressures you guys run?
I figure the trailer will be just under 1K loaded and the previous owner had the tires at 20psi. Does this sound about right for the road?
Seems like I could go fairly low since its such a low amount of weight for that tire vs what a Jeep places on it.
stevec
Probably about right. I have 32's on my Samurai - about 2500# as is - and I run about 20psi on the street. On dirt/washboard roads, you'll probably want to air them down some, to keep it from bouncing.
LexusAllTerrain
I am using 22psi on the street and about 10psi offroad,(33x9.5x15 )my trailer is about the same design as yours, but different!
Gaidheal
I'd suggest the same for the tow rig - chalk test the tires at the load you will be running in the trailer.
:beer:
EBT531
Things went pretty well for the first time out. Learned a few things, like 16-18psi is good for the street. 10psi worked good offroad. Pulled nice and only cost me about 2mpg on the Hwy.
Had the hatch open on me once :Wow1: turns out the lock needed adjustment.
Plenty comfortable to sleep in and had plenty of storage space. Over all I am happy with it.
LexusAllTerrain
Nice looking set-up, I wish you would post more pictures of your trailer!:sombrero:
V45W_Proto2.5
