This is just a simple list of issues which have cropped up in this chassis for any serious off road work. I have discussed suspension in another thread and I will add to this thread as issues come up but so far:
1: super single conversions, several groups do a single 19.5 rim
2: wading depth is pretty poor at 300mm.
3: Standard fuel tank is way too low
4: Need a protective screen to cover gap between inter-cooler and radiator
5: Dust sealing is atrocious
6: front steps need to be modified higher
7: transfer case is lower than chassis rail and really needs a "bash plate" to protect it.
8: rear shock absorbers are in front of the axle and get annihilated by stones, need a protective shield of some sort.
9: front sway bar is way too low, needs to be moved or removed altogether (potentially dangerous.....)
10: need to fit screens between engine bay and wheel wells, these are available commercially as are wheel arch flares etc.
More to come......
DPD exhaust should not be submerged
wiring insertion points in gearbox etc
fuse box needs to be relocated
brakes take a long long LONG time to start working again after submersion
More to come......
