Glock light/laser recommendations
FettsWay
Just got my first Glock model 22 40 cal. and I am looking to find a light/laser to train my aim with and watch for how the gun moves as I fire and squeeze the trigger.
I have been looking online, but am completely new to these things. Am hoping to spend under $100 if possible. Maybe later on once I get more into this, upgrading and spending more money will make sense, but not right now.
Hoping for suggestions. Thanks.
Corey
OverCamping Specialist
This is way over your budget, but is considered one of the best.
160 lumens if retina ripping light, and a .5 MW red laser.
My Glock 21SF with Surefire X400
http://www.surefire.com/X400product
kjp1969
Using it for dry fire practice only? If so, just pick up a cheapy laser pointer and tape it on.
If using it during live fire, I don't think a laser is going to do what you describe above- the only movement you see will be due to recoil.
robert
The TLR1 is a great light for around $100.
I'm not sure about the full sized Glock 40 but I know there have been some reliability issues with the G23 and mounted lights. Check some of the law enforcement forums for more info.
xj joey
I have a lasermax in my glock 30. Its nice being able to turn it off and on unlike the crimson. But its $300 bucks. Some people dont like it because they think it could fail and lock up the gun because it replaces the recoil spring/rod. I got about 500 rounds with no issues. I like it for shooting at an indoor range to see how bad my hand is moving when I pull the trigger. Or when someone decides they want to sneak in at night. Really cant see it outside.
Bult4mud
I am not a huge fan of Lasers. Problem I see with training with them, is unless you have a spotter you spend more time looking for the lil dot instead of watching your front sight.
Best training i have found is the ball and dummy.. Have a friend load the mag with live and dummy rounds.. when your break the shot on a dummy round and your gun dips you will know you jerked the trigger. Unload and to 5 good dry fire pulls.. then start again.
I would say save the money from a laser and buy $100 worth of ammo.. Or buy a .22 conversion and run that on your glock frame until you get used to the trigger.
If you have to have a laser check out the Laser max that mounts to your acc. Rail.
Good luck
Roy
cnynrat
For a light I recommend the Surefire X300. Don't be tempted to go cheap here, you want a quality unit that you can count on.
As for using the laser as a training device, I'd recommend you spend the money on training classes or ammo instead. Dry fire practice costs nothing and is a good way to improve your trigger control. As useful trick is to place a coin (a dime will be the most challenging) on top of your slide near the front sight and practice dry firing without dropping the coin. Do that for ten minutes a day and your trigger control will improve very quickly.
ssc45
I see no need for lasers on handguns. I see people try to use them as a training device and they end up relying on the dot and miss the point of training. I feel that one has to master the basics of gun manipulation. This starts with getting the grip right and then work through sight alignment and then trigger control. Too often, these basics are skipped in favor of this new rage, the laser. If you are working on the proper basics, then as you dry fire, you will be concentrating on your front sight and see what movement there is. Of course there are other parts to the story, but this is the start.
Second, in the gun industry, we need new "stuff" in order to sell product and this is one of them. Then people set up new classes for it and they sell.
Third, Having a bit of insight with some swat teams, I know of some who have tried the laser approach and have determined them to be unacceptable. Why, try to do an entry with numerous lasers and no one is sure of which one belongs to them. People begin to look for the laser dot and it takes away concentration on the tactics. Lastly, the bullet doesn't always go to where the laser is pointing. They need to be sighted in and they do change zero.
My advice is to get some training in the basic gun manipulation skills and then move on to drawing, shooting on the move, strong hand/weakhand, malfunction skills, reloading etc. Remember, many people have learned to shoot without the "aid" of a laser and will continue to do so. Just my 2cents. Take it for what it's worth.
Cheers, SSC
xj joey
Mine hits where you put it. Lasermax dont have to be sighted in. I could shoot quarters if I could keep from moving. Being that my gun is for home defense I feel the laser is helpfull. Its easier to put a shot on target in the dark with one then trying to line up sights in the dark. You can also shoot around and object your using for protection and not have to be behind the sights.
gary in ohio
For the true marksman who want to use the guns to its fullest, have the time and interest to train and train some more. No they are not needed. For the self defense people who want a tool to protect them-self with the laser is perfect for the job. Point and shoot..... For my carry gun, I am filling my piggy bank for a lasermax.
Goldenbora
