Inexpensive Work Stand Needed
Maximus Ram
So I did a search here and came up with nothing. So what is everyone using to hold and work on your bicycle ?
I have googled stands and found a few..also found some on e-bay, but am curious as to what the innovative folks here on ExPo use. I have even seen plans for home built, but can't seem to find the clamps they use at my local home improvement stores./
So what do you use ?
Thanks,
Matt
Christophe Noel
In the late 80s and early 90s I worked for a couple of the most well respected bike shops in the business. At both of those shops we had proper work stands, but most of us used rope hangs. Two ropes suspended from the ceiling. One to the seat post, one to the stem. Sounds lame, I know, but I've seen the best mechanics in the biz prefer this. I know I do. I use webbing as it's softer on fancy bits. Costs less than $10 as long as you have the most important part - a ceiling.
4xdog
I use a toe strap looped over a water pipe running across the ceiling of my basement. I hang my bikes from the nose of the saddle to work on them.
The bike stays quite well balanced with or without the wheels on. Lets me have 360° rotation and the ability to turn the cranks, spin both wheels, and test front and rear brakes.
Couldn't work better for me. I've used the same system for over 30 years. Total cost -- about a buck.
Don
Maximus Ram
Interesting...never heard of hanging a bike to work on it.
Unfortunately, the garage really doesn't have room to hang anything (else :D ) in it.
I'm thinking of something in the way of being able to clamp it to an outside bench or even off of a hitch bike carrier.
I've tried the carrier itself, but it's no good for holding my daughters Schwinn Breeze.
keezer37
I take it you're familiar with Park's bench and wall mount clamps? I believe they sell for $100 or less.
http://www.parktool.com/category/bench-wall-mount-stands
I use a homemade mount for my carrier but I'm figuring you don't have the room for it. It is adequate for maintenance and works for storing the carrier/bike.
kjp1969
I use either the hitch mounted bike rack or my own version of the rope stand- a cam type tie down strap. If nothing else, hang it from the garage door- the one you opened to get into the garage!
I also made one once that was simply a 2x4 screwed to the workbench and hanging out into space, plus a couple of cleats that kept the bike top tube from sliding off.
Corey
OverCamping Specialist
You mean like this ghetto setup?
I bought a nice new stand a few years back when I bought my new mountain bike.
I use to have a Park stand, but I gave it to my X's husband to use to tune their bikes.
I now use a Topeak PrepStand Pro.
Sets up easily on my deck outside for when I need to clean/lube the chain, and do other work to it.
I got it for around $200 though, not the high price that the site shows.
Corey
Looks like homeboy did not get the memo about the second rope.
Never seen this done before.
All the shops I have used in the past had big stands with a huge base to prevent fallover.
Corey
Ahhhh, I see I am famous again :sombrero:
Homeboy loves me, why else would he stalk me in threads over here all the time.
slowtwitch
Neither had I till I went to Europe, where it seems to be common. Cheap, easy to move the 'stand' around, more floor space, no worries about over clamping on carbon, messing up paint, pulling out more seat post, etc.
st
Goldenbora
