Homebrew Jeep Modifications(DIY)
hughes278
Limb risers...
is this home made? i love it do you have a write up?
trust
revised burrito warmer
My orignal warmer worked fine but I deided I wanted something wide enough for a slice of pizza and with a lid to minimize dust and to keep the food in the warmer so I threw this togetherburrito warmer 007.jpgburrito warmer 006.jpg
theksmith
My orignal warmer worked fine but I deided I wanted something wide enough for a slice of pizza and with a lit to minimize dust and to keep the food in the warmer so I threw this together...
nice, i also recently re-did my oven. now i can fit 2 burritos instead of one!
it also now holds one of these pans easily.
you can pre-make meals in these pans, then wrap them up in foil and just place a pan in the engine "oven" at lunch on the trail to heat up for dinner back at camp (provided you are wheeling all afternoon).
more info: http://offroadpassport.com/forum/showpost.php?p=15217&postcount=540
the old one was pretty much the same thing, but not as secure of mounting and was one size smaller pan:
Cityslicker
where did you get that pan? I'd love to have one of them in the XJ... the engine runs at 210 like a clock... I could roast a turkey..
trust
Very nice theksmith! yours is quite sophisticated, mine is just two shallow baking pans a d a pair of small brass hinges held closed with a binder clip, I think I'll look for a cabinet latch like yours, that's much cleaner
thanks
trust
simply attached to existing bosses in the valve cover, it's a 4.0L jeep head and valve cover on the the 4.2L straight six with MOPAR efi, when I saw the flat VC and the mounting points there already it seemed a no brainer
FWIW, it is not as effective as i had hoped at highway speed, on the trail it works great, on the open road, not as well
4X4NDAD
image.jpg. This may be a better look. 2 inch spacer lift, diy highlined. Yj half doors. Front bumper hack with ebay light bar.
HAFICON
Oh where to start.
Built soon to rebuild Dual battery tray battery hold down.
In the process:
Finished and wired works great.
Over head console with switch and gauge pod. (Have since modified this)
JK windshield light brackets:
Built my own limb rises cost about $12
Bracket that mounts to OEM booster mounting bolts for a 4 relay, relay box.
Built a tail gate speaker box: 2x4 frame with 3/4" shelving made to withstand a beating and coated with bed liner for water resistance:
Amp mount to the side of the box.
HAFICON
Modified console to work with sPOD have to build new CB mount as the current one was for soft top only.
OBA air manifold, aluminum block with sensor and locker solenoids, all hose is braided stainless steel with Aeroquip style fittings.
Lastly not really home brewed but I did not pay someone to do it so yea it is :) Ignition hot distribution block for powering switches or really low amp stuff.
Mounts behind the glove box:
