1967 NADA 109 cant make up my mind on this 2.6 power plant
aka rover
I'm not trying to stop you from your chosen path but a Chevy six can be done quite neatly in a LR engine bay. That's a 292 but only the height changes over a 250. Like you, the original installation was pretty ropey.
I really like your install on your chevy Six "VERY NICE"
But its just not for me.
Thanks Ed
James86004
I have two running NADA 6s but im concerned about being 3000 miles from home and having a problem with it and not being able to get parts. The purpose of the rig is to travel long distance and being selfsustained. Do you think it would be reliable for long distances with heavy loads of gear. If I knew they where dependable,It would be nice to here from someone that has driven one long distance with success. No matter what motor goes in the sals will be in there.
Sorry, I have been too busy between work and exploring to get on here in a while, but I can answer this question. In the last couple of years we have done several 1000 to 2000 mile trips and had zero engine issues. Death Valley, up Hwy 1 in Cali, all around some really remote parts of the Four Corners area, and the engine has been totally reliable. We have had a couple of carburetor issues where the float setting changed, resulting in a richer mixture and lousy fuel economy, but that probably had to do with the oxygenated fuel we were forced to buy. Carb rebuild kits are easy to carry, though.
Personally, I am far more worried about the Rover gearbox and the Fairey overdrive than I am about the engine.
James86004
That must be the cleanest in line 6 conversion I've ever seen!
It is real nice. I got to see it in person before he shipped out and it looks even better than the photos show.
My Dormobile friend living is CH thinks everything automotive there is made by magical forest elves and priced accordingly.
greenmeanie
Ok, I'll save a lot of messing around with images and link to an album with some build pictures
I don't think you have to log in to see them. Any questions just ask but this is AKAs thread.
repete
Brilliant conversion job! I'm dying to know how you mated that series steering column to that p/s box. I'm sure I'll have many more questions once I can view the pics from a computer.
aka rover
No problem with asking questions about that beauty..!!! Im interested as well on that steering conversion as im converting mine to power as well. I just picked up a P38 box to do mine.
Cheers Ed
greenmeanie
The steering uses Borgesson U-joints and a collapsible intermediate shaft (Very important for safety).
I modified the column in the following way:
- Removed the aluminium box off the bottom off the outer column. I made up a very heavy bracket to emulate the mounting holes of the box so the old outer column remains in the same location using the same mounts to the chassis (Pays to measure how far the top of the column sits out from the dash before disassembly.
- I used a mounted bearing from McMaster Carr on the bracket to mount the base of the inner column. I believe Inchworm also sell this part.
- I then took the Rover inner column and cut the scroll for the Burmann nut off the base and had Ike at Pangolin 4x4 weld a Borgeson spolined stub shaft onto the bottom to extend it a bit. I used to work in aerospace so had the weld joint X-rayed just to make sure of its integrity. Ike also machined a groove into the shaft to take a snap ring. I have a couple of spacers in there and the spring under the steering wheel provides preload on the bearing.
I have now moved to a location where welds on steering components are not allowed. Fortunately I have an old 101 column that I will just cut down and machine flats for a DD connection to the U-joint. Simple and no welded joints. You could try machining the standard scroll down to achieve the double D shape but IIRC there isn't enough meat.
Here are some piccies which should clarify some of my haverin.
aka rover
How are you going to do the frame beefing?
Mike are you refering to the steering box beefing or the motor mounts, for the steering box I am building a frame plate on the outside for a strong surface then i will drill and sleeve the frame and so the box will be tied to both sides of the whimpy thin frames:).
I have had great success using this method in the years past on other steering conversions I have done. When the time comes to install the box I will take some photos and document as I go.
The motor mounts will be hung on the frame to pick up the top and the inside rail to help spread the load of the motor.
Ed
aka rover
greenmeenie
That looks very nice that's what I kinda had in mind, very clean when all said and done.
Thanks for posting the pics
Cheers Ed
DanoWall
