05+ Radio Facia Removal??
viatierra
I finally picked up a Ram mount for my GPS and want to investigate where I want to install it.
I've done a little searching around but haven't found anywhere that discusses removing the textured aluminum facia around the radio. Anyone here done it?
maxama10
Welcome to Nevadafornia
stick a putty knife under the climate control and pry, it just pops out, after that there are 4 bolts holding in the radio, 10mm I believe, undo those and then the entire thing pops out if you pull. From there you should be able to take of the faceplate.
-Max
Dave Bennett
Adventurist
-Max
Exactly, but I recommend using a plastic putty spreader from the local paint department to avoid scratching the dash... four 10mm bolts are all that secures the head unit.
Clemtiger84
