jordanoverland
SOLD SOLD SOLD
Hello, up for sale is my 1999 cherokee. i bought this jeep with 95,000 miles on it bone stock. in the matter of a few months i spent alot of money and did alot of updating on this thing in order to prepare it for my overland trip across the country and through british columbia. the trip was about 10,400 miles and i completed it in about 6 weeks. (yes lots of highway miles in there). im ready to build the next rig and would like to get out of my cherokee considering it was purpose built for this trip, im hoping someone in the overland community can put it to good use.
specs:
-4.0 straight six - 110,000 miles - had the head planed and put a new head gasket+studs on it 3000 miles ago, new exhaust mani, new 4 hole injectors, all new gaskets. New water pump, belts, 130 amp alternantor, ac pump, radiator, trans cooling lines, fan clutch, fuel pump, all fluids, all hoses, about at 97000 miles.
- full stainless exhaust, highflow cat
-automatic transmission
-chrysler 8.25 in the rear and dana 30 in the front
- all new factory pre-bent brake hardlines and soft lines, new caliber, drums, pads
- all u joints (drive shaft and axle shaft) have been replaced
- rustys 3in hd lift (hd for bumpers)
- 3.5in leaf pack in the back with 3in worth of add a leafs from rustys to accommodate the added weight, can be removed or unshackled on the ends for softer ride.
- 31x10.5in cooper discover st maxx tires (these things are bullet prove)
- new tie rod ends, moog wheel bearings, pitman arm, upgraded adj. track bar.
- Smittybilt front bumper with bullbar and smittybilt 9500 winch
- smittybilt rear bumper with swing-out tire carrier and reciever
- smittybilt rocker armor plating
- custom one off roof rack, can hold over 800 pounds
- amazon leds wired into switches mounted in the overhead console
- cb radio
- dual optima battery setup. yellow top inside cab.
- 600w inverter
- drawer system with cabinet space- homemade, nothing special but gets the job done.
- smittybilt rooftop tent
I change the oil every 3000 miles with mobile 1 full synthetic and mopar filters. The jeep is well maintained and in fantastic condition for a 99 cherokee. There is no rust on the car, i have replaced the rockers though. The underneath is undercoated and oiled. I am positive there is more I am forgetting. the jeep is located in western Pennsylvania, i would be willing to travel depending on the location.
You can contact me on my gmail at ridegreen322 at gmail dot com. email for more pictures. This jeep went 10,000 miles without a problem, i wouldn't hesitate to drive it across the country and back the way it sits. Looking to get 15,000$ obo
specs:
- cb radio
- 600w inverter
