2002 Chawton White - A Buildish Thread
  • Thread starter Thread starter ZG
  • Start date Start date
Exactly.... they're a pretty practical tire size. As long as they're not worn funny they do fine at 75mph.
Little update...got some new shocks in :)
I went with 11" travel, 28" extended. I will certainly update you when I have them installed. Waiting on my paragon 6" extended brake lines first...
Thanks David! I have done tons of things but this thread only shows a couple. I'll update when I can.
Rear RTE springs and shocks are in. As well as the +6" custom SS brake lines. Very happy with the results, only slight modifications required.
New bumper and winch installed, very happy with the setup. Will be cutting the sheet of aluminum I picked up for the new skid plate.
Thanks Kent, I appreciate the insight you gave me! Can't wait to cut the sheet of aluminum I just got for the new skid.
It looks like you may have trimmed the wheel well area of the bumper. Is that the case? If so will you take a few pictures? My tires touched the bumper when I was in Moab two weeks ago.
Thanks,
KENT
I did trim, and was going to plate it but it was at the blaster and he coated it before I could plate it.
I'll take photos, I probably would have trimmed less if I did it again.
Cut the sheet of aluminum I got into the design of the original skid, did a better job than I expected... (done with a cut-off wheel)
Bobbyjr
