atomandeames
This is a 2006 Land Rover LR3 SE that has been built for overland travel. I first purchased the vehicle in 2021 and have put just about 50k miles on it. It's been across the country several times and all over the southwest. In my nearly five years of ownership it's never let me down: it's pulled sedans out of snow banks at ski resorts, rescued Subarus in Colorado, and taken me to some of the most gorgeous, off grid camping spots in New Mexico. This vehicle has been my daily driver for most of my ownership of it and has repeatedly proven its mettle off road and through multiple blizzards. The truck wears its age as a badge of pride--the paint and clear coat show the signs of years under the harsh New Mexico sun and desert pin striping from many adventures, but mechanically it's been well looked after. All service records will be included with the sale. Here's a quick rundown of all the essentials:
As with any older vehicle, it's important to note the things that are aging well and the things that will require attention soon or are a notable departure from how the car should be operating. In the spirit of radical honesty, I've separated these notes into three categories:
The vehicle is located in Los Alamos, NM and I'm asking $8500, though I will entertain reasonable offers. I'm happy to answer questions in the thread.
- 4.4L AJ41 V8 (factory rated for 300 hp and 315 lb-ft of torque)
- 6 Speed ZF Automatic Transmission
- Full Time 4WD with Terrain Response
- 198,000 miles
- Clean Title
- ARB Front Bumper
- Warn VR EVO 10S Winch with Factor 55 fairlead and flat link
- Diode Dynamics SS3 SAE Fog Lights
- Baja Designs LP6 Pro LED Spot Lights
- Baja Designs Squadron S2 Pro Ditch Lights
- Custom S-Tech 6-switch system with Carling Rocker Switches
- ProSpeed UK Expedition Roof Rack (with aero kit, heavy duty floor kit, cross bar kit, and awning brackets)
- (5) Tuffant Kimberley wheels with 265/70R18 BFGoodrich Baja Champion All Terrain K02 tires (Installed 2022)
- (4) OEM Ten Spoke Land Rover Rims with TPMS sensors
- Terrafirma Raised Air Intake
- Terrafirma Rear Ladder
- Midland MXT275 GMRS radio and Alamosa 48” GMRS antenna
- GAP IIDTool currently paired to the vehicle's VIN
- Various spare parts, bulbs, etc.
- Coolant system rebuilt, transmission fluid and filter replaced (2021)
- Front wheel bearings replaced (2021)
- Driveshaft carrier bearing replaced, rear differential seals replaced, front and rear differential fluid changed (2022)
- Rear wheel bearings, brake rotors, and pads replaced (2022)
- Coolant reservoir tank replaced (2022)
- Rear pinion shaft seal and outer tie rod ends replaced (2022)
- Alternator replaced (2022)
- Engine oil cooler replaced (2023)
- Battery replaced (2025)
| The Good | The "Meh" | The Bad | |||
| The batteries in the aftermarket key fobs are dying and will likely need to be replaced. |
| The transmission is not as silky smooth as it once was and can sometimes "klunk" when coming to a stop. I suspect installing a Zip Kit would remedy this issue. |
| The dash is cracking above the passenger airbag. | |||
