255s on a daily driver?
shawkins
With my 5-speed in my '98, I think my mileage went up due to the lower RPM's while cruising the highway, which is pretty much where it spent most of its time.
xcmountain80
You have a similar setup to me. I have a 02 4Runner with TJM-17 winch bla. bla. bla. and 285/75/16 with a consistent 17mpg. I run 2 sets of tires BFG AT's and cooper STT's I am getting rid of the AT's for a set of Nitto Terra's. I went from 19-21 mpg with 265/75/16 to the current 17mpg. Re-gearing doesn't seem to be a viable option given the cost. So I'm just fine with the 17mpg I imagine my air flow has changed considerably since lifting the vehicle but seem to think you should still have good numbers with the 255's.
Aaron
xcmountain80
expeditionswest said:
You must regear with the automatic. Your mileage will go to the 13-14 range without regearing and OD will be all but useless. :sombrero:
But they would look cool...
Scott are you referring to the 265's on a 4Runner? Because thats what mine came stock with and was pushing 19-20mpg. with the 285's it went to 17 and OD and speedo are off 6%. I'm running the 4:10 gears as well....
Aaron
Scott Brady
Founder
With a 3.4L V6, 4 speed auto (.705 OD) and 4.10 gearing, 255's will require regearing to make OD usable again.
Of course, I drove around for nearly a year with those tires on and 4.10 gearing but drove around with OD off and suffered at the pump.
jeffryscott
2006 Rally Course Champion: Expedition Trophy
The fortunate thing for me, with my recent acquisition of 255s, is they are already mounted - I won't need them as my daily driver wheels. Although, I'll probably be too lazy to take them off once I put them on.:jump:
jeffryscott
Aaron
Aaron, SWEET looking rig. can't wait to finish getting mine setup.
xcmountain80
Thank you jeffryscott , I know one is never finished, but I am very close to the ideal setup. The rig itself is nearly done there are a few odds and ends "locker+ 430 gears or whatever I May be able to find to fit the ARB Locker" and a few other things. I would like to make a roof rack but just a flat one so I can put the tent on it and maybe a light or two. Super flex joints from Sonoran Steel are again desired but not currently needed. I have no desire for it to be any bigger, because at this point its a perfect blend for travel, offroad, comfort. The only reason gearing has not taken place is because of the associated cost of locker and f+r gears ends up being about $2k So not to further hijack the thread good luck and if you have any questions I've probably scratched my head over a thing or two.
Scott! what type of mileage do you get now? and with what gear ratio? Wow I just looked at your site and your running 5:29's. How much better is your mileage?
Aaron
Ancientsojourners
