Martinjmpr
Wiffleball Batter
Okay, so here's the story:
I went elk hunting this past weekend up northwest of Meeker, CO (gorgeous country, btw!) Didn't get anything but had a great time with my brother and his friend and some of my girlfriend's family.
Anyway, we stopped for gas and lunch on the way back in Glenwood Springs. I filled the tank at the Bradley station (i.e. cheapest gas available.) Since we weren't in a terrible hurry and it was a nice day, I just set the cruise control at about 65 for most of the trip. Glenwood Springs is right around 6000' above sea level, and there are two passes between Glenwood and Denver, Vail Pass (10,600') and the Eisenhower Tunnel (11,000') so it's about equal parts up and down.
I got back on Tuesday night, drove to work Wednesday and today and decided to fill the tank since gas is going up.
I always measure my MPG when I fill up, and I always do it the same way: Since I set my tripmeter to zero after each fill up, I just look at total miles and divide by total gallons. Well, it was 208 and some change, and 7.67 gallons. It came out to 27.19 MPG! :Wow1:
Has anyone else had results like this? This is on an '04 Taco, V-6, 5 speed 4x4 with a cab-high shell, carrying two people and probably 200-400lbs of gear. Still using the stock 265/70R 16 BFG Rugged Trail TA tires with 53k on the clock (I'll need new tires soon, btw.)
Now, I don't believe I really got 27.19mpg. I think what may have happened is that the gas station I went to has a more "sensitive" auto-shutoff than some of the other ones I use. If so, then I should get a lower than usual MPG rating with the next tank. I'll average the two to get my "actual" MPG.
However, it is unquestionable that I drove over 200 miles and my tank was still well over half full, so even if the MPG was "only" 25, that's not bad for a V-6 4x4!
As I said, what I'd really like is to "reality check" this with other Taco drivers to see if this is really possible. If it is, I'm stoked! :wings: My Subaru got 28-29 in the real world on a couple of occasions, so if I can hit 24-25 in a bigger and much more capable vehicle, I'll be thrilled. Now if only the tank was a gallon or two bigger...
