270 amp bolt in Laternator for 80 series
Bought it but never installed I stuck with 15 amp upgrade I already did. 500 u pay shipping 508-7188253 text richie
The available OEM alternators for the 1FZ-FE (4.5L gasoline) engine are rated up to 80 Amps and only produce 60 Amps at idle. This heavy-duty alternator generates a maximum of 250 Amps at normal driving speeds and produces 185 Amps at idle. With this SBC alternator, you are gaining 125 Amps at idle and up to 170 Amps at cruising speeds.
The XP series of SBC alternators are assembled using DENSO components and produce the highest idle output. They feature a larger housing while still retaining OEM fitment without any modification required. They run cooler and are virtually indestructible. This alternator is designed to be an exact replacement to the OEM alternator for the 1FZ-FE engine.
A precision CNC 6061T6 aluminum pulley with a .002 hard anodized coating is installed on each alternator for maximum output and durability. This alternator comes with an unprecedented full two year warranty.
heres the link https://www.m2kinc.com/detail-sbc-t4-5-250xp-39-42-38-2.html
rocksandtrails
