5 lb propane tanks
vtlogger
quick question?? where are you guy's getting your 5 lb propane tanks and mounting bracket's?? I would like to find the bracket's you are hanging on the side of your trailers
Mark Harley
Find a shop with a press and bend it your self.
vtlogger
Mark .. I saw that on another forum and thought it was awesome!! I'm really thinking of going that route ... hope you don't mind me taking your idea
vtlogger
I do have one other question ... can I use the 5lb tank to run my coleman stove?? are you guy's doing it? and what do I need to make that work?? not sure with out digging it out what model it is .. older .. but I use the small green tanks on it now ... the plan is to get away from throwing those out and just refill what I have...
Crush Jeep
If you can weld or know someone who can do a little metal work it's a lot cheaper than buying one. This one was built from left over pieces from the trailer build. Total cost less than $10.
cj_josh
Go to a fire extinguisher supply company.. I got mine from there - just bring your tank. The company I went to had a dozen or so different mounting brackets, so I tested them out and went with the one I liked best. The best part is that they were a fraction of the cost of the propane tank mounts I found online but more than substantial enough to hold my tanks (they've held up well on my journey through mexico and Central America to date). I'm using them for 11 lb tanks but would imagine they would have brackets that would fit a 5 lb tank...
bdpkauai
